WEB HOSTING COMPANY TO RECOMMEND!
skysurfer78
Unless you are looking at more SaSS businesses offerings such as Adobe Catalyst, or 60secs CMS and such services, what you are describing basically is the software layer.
What you wanted can be achieved via Joomla, Drupal, Liferay, with Magento, Prestashop, etc.
As for web hosting, you can choose shared web hosting, VPS, or colo your own server, or engage in cloud hosting such as Google App/Compute Engine, Microsoft Azure, Amazon Web Services etc.
Thanks Davidktw! You have given me a good direction what to look for. I am doing research on it now. Now comparing SiteGround which seems cheap and able to support a Joomla CMS and Magento eCommerce for expansion and seems cheap at 47USD per year (I hope that consider cheap). Separately, some website builder also caught my eyes like Jimdo and Weebly, really user-friendly without coding. Do you recommend to go for Jimdo and Weebly kind of service? They don't seem to emphasize so much on up time, underlying platform but focusing on SEO, mobile ready features which sound attractive. Any possible drawback?
davidktw
I think ready made platforms always have the drawback of limited customisation and extensibility. Where you get most popular features readily available to you so that your time to market is short, customization will be an issue if you need more than what is available out of the box.
Your own customization using infrastructure hosting environments means you will need more development time and also better staffs with expertise in this area. The value you get out of it is you get the opportunity to make things the way you want it to be. Not easy but possible.
I, myself, don't really have experience using readily available platforms since I enjoy meddling with stuffs myself and I have the technical skill set to make things work. Moreover my objective is unlike yours where it's more business centric, so I suppose I can't be more effective in advising more.
From a solution architect perspective, there is no limitation for you to stick with just one type of hosting. Look at the ready made solution and see if you have options to customise, especially in the area of integrating with external system via RESTful API, availability for you to install plugins or modules or so forth. In this way, you can enjoy the readily available futures, but when you need to extend features, you either redirect the users to other platforms also designed by you, or you need to deploy RESTful API elsewhere and integrate with your existing systems.
There are numerous approach to achieve single platform integration despite they are actually deployed in multiple platforms across the Internet, using SAML or SSO federation, web services or RESTful approaches, reverse proxy concepts and a lot more.
Do some research about it. Feel free to post more question when in doubt :)
Update:
If you are a developer, knowing how to set up web servers, databases, working with linux systems, you can get quite a bargain working with AWS. No you will not have those fancy nice looking UI panels, but you get flexible plans and possible minimal contract too.
With USD38/mth, you can get 200GB of data transfer in+out, static IP, 160GB of volatile diskspace, 20GB of non-volatile diskspace(5 snapshots at 5% changes daily), 1.7GB of memory, 1 VCPU, almost any linux OS distro you like, network bandwidth should be roughly 100+Mbps, dedicate VPS like hosting, on 1 year reserved hosting. The uptime is at optimistically 99.95%.
If you want high availability at approx the same price range, scale down the machine types to a less powerful system that run at 640MB, no volatile diskspace, only 20GB each, but you get 2 separate servers hosted at different data centres. You also get to have a virtual load-balancer to distribute the load. These smaller instances cannot take in high load, but are stable between 1~2VCPU. 2x such server configuration will incur USD36.37/mth
With AWS, you can have enterprise level solution with very attractive price. One thing I don't like about those shared hosting is they tend to over-provisioned their system. If you want nice looking themes for your Wordpress or Joomla, try www.yootheme.com.
jolimsc
Local Web hosting services
I am looking for good (and hopefully cheap!) web hosting to create a website for a small software business I just started. Also to host email. I registered my domain through Exabytes.sg and they offer web/email hosting as well. Anyone has experience with them? Any other recommendations are gratefully welcome.
RayOfLight
i will be running a e-commerce site soon.. which hosting is recommended? any idea what kind of hosting like qoo10 or groupon are using?
shiki05
Hi,
I hope you can give me some advice..
I'm trying to set up a small business website.
I have zero knowledge of html.
I heard that wordpress.org is easy to build a business website.
Which host would you recommend?
I tried Bluehost but they have changed simple scripts to Mojo and i can't even install wordpress.
Is there a stable host that offers good customer service (to contact from Singapore), run me through installations and set ups, and very affordable?
thanks much!
jemych
I will suggest you try wix.com for website and oryon.net for email.
why wix.com and not Wordpress. Wordpress has vulnerable plugins and subject to hacking. wix.com on other hand allow you to create html-only websites. There is no way one can hack html-only websites.
I change my company email to oryon.net business email 9 months ago. so far the uptime is 100% based on per minute monitoring service on the mail servers. Speed is good for 850 email accounts.
davidktw
I wouldn't be too sure about static html websites are safer. While I agree static html websites will not by itself exposed vulnerability that insecurely designed dynamic websites may exhibit, one must understand that security happens vertically across all the stacks involved. May it be application layer, network layer, platform layer etc.
If we look from a holistic perspective, while Apache web server may have been long standing in the community, vulnerabilities are found from time to time that may allow intentional hackers compromise your website even if it is just html only. There are also other areas in a system that may be compromised, such as your FTP server, mail server, administrative control panels, DNS servers and so forth. For shared environments, it's not unlikely that one of these servers sit in the same physical hosts as the web server hosting your website, hence they make good candidate for hacking. Even SSH servers are good candidate for hackers.
Given the vague stacks of the actual system that may not be visible to normal consumers, there is no absolute confidence that websites hosting HTML only webpages are safer from hacking.
Next we also need to consider the following prospects in ecommerce websites, is that owners normally have more expectation of what an ecommerce site is capable of. It's not usual to find even bloggers have subscribers based mechanisms that requires server scripting to help create a more interactive website.
If a business owner started off with a static only html site, it makes it more painful to convert to a content management site later. Alternatively business owner can implement his/her own server based solution which have a much higher chance of introducing security flaws and also reinventing the wheel.
Despite content management systems such as Wordpress, Joomla, Drupal may have reported security vulnerabilities, they are after all globally tested by a lot of popular businesses, and each time vulnerabilities are patched. If it's a self customized one, it would be a lot less confident to assume they are safer.
It's a balance one need to think thoroughly about.
blade007
hmm... im not a pro in such stuff but i recently tried to create a website with Wix and it is using HTML5.
Lots of issues for the visitors for the website as certain version of internet explorer seems to be not compatible. Therefore alot of them could not access the site. :(
ievision
Good to Try somemore free
Key Things to look when choosing a webhosting :
  • Look for Web hosting website that provide 24/7 technical support representatives.
  • Uptime at least 99.99% online.
  • Every account is backed by at least 90-day or more money-back guarantee.
  • I have try this webhosting website which i find it very excellent till now has not give me any problem.
xorion
call 6100 0096 and quote "john from avosolutions" they will give you a good deal.
otacon
i m looking for a company for email hosting only for my company of less than 10 staffs. minimum only need 2GB for disk space n at least 8 email accounts. i have found webvisions, Limebox, Poznet, Vodien and Newmedia to support email hosting service. so fast, webvisions is most worth for money.
1. Webvisions / 15GB / 15 emails / $114 per year
2. Limebox / 20GB / 20 emails / $84 per year
3. Poznet / 10GB / Unlimited / $300 per year
4. Vodien / 5GB / Unlimited / $120 per year
5. Newmedia / 20GB / 10 / $256.80
i shortlisted webvisions n vodien but i did not find much reviews on webvisions n found quite a number of positive reviews on vodien. But ideally, webvisions provides 15GB disk space for $114 which is quite cheap. but if vodien is more reliable n meets my minimum requirement, i can go with vodien too at $120.
any advise???
PS: currently, my company is paying $54/month for 1GB webhosting which is too expensive
smurf75
Hi , Can someone help me , as i don't have any knowledge about these.
My company intend to have a webpage and forum , what do it meet the requirement ? Is HostPapa reliable?
decsup
im using ipage as host. however found it is slightly slow to be surfed in local.
anyone has any idea which host is best surf locally? i mean fastest loading speed when surf in singapore
reflush
any advise???
just test to call the hotline support, how fast/ long the phone will be pickup.
i have bad experience with webvisions, maybe that time all staff is on mc.
but the most important how many technical support the webhost company have?
company as big as webvisions (example) if have only 2 technical support, do you think ok?
hanneng
any advise???
why not consider Windows Live Domains/Outlook.com for your email solution.
You can create up to 50 accounts in your domain.
the best part is FREE
