$59 to 79... depends on the size and %.
For pits, result is slow.... depends on individual..
Home care is always slow, faster and more obvious result, go to a doctor.
Skin pharmacy will teach you how to use... anyway first time user put on for 5 min... gradually you increase to 10min, then 30min, then overnight.
Another treatment that works better is the micro needling or derma roller.. there are some beauty salon selling it.
You will need to buy the meso/derma roller, a good collagen promoting serum and a aftercare gel. And you will need to learn how to use the roller, otherwise you may tear your skin.
My meso roller is 0.5mm needles, it will not bleed your skin. Professional using on their customers or patients is normally the 1.0 to 1.5mm, your skin will bleed... search in
youtube for more info.
My aftercare gel is Renewderm from Korea (Korean doctors are using too), is available in Singapore. Normally after you do micro needling, you will feel a burning sensation on the skin and it is raw... after renewderm, it subsides within minutes plus it has snail extract, it repairs tissue and promote regeneration.
