[Maylyn's Review] ASUS RT-AC66U Dark Knight Rises
thenakedshades
thenakedshades
I don't have authentication errors, but on my Galaxy Nexus, it always keep connecting and disconnecting on 5Ghz, didn't have this issue on 2.4Ghz.
After i changed channel from 149 to 36, it worked for me and didn't keep disconnecting as per this:
Fix For Nexus 4 4.3 5ghz Wi-Fi issue - Android Forums at AndroidCentral.com
Not sure if it helps u or not :)
Okay! I will try and let you know! just changed it.
It is not working! it's good for a day then it started having problems again! ASUS@SG?
Pepe
Launch price $359 + freebies.
ykeen
Moderator
Moderator
When's the best time with lesser crowd?
The redemption booth at the back of Asus booth 6311 ..
You go before 5pm best lor.. Or think anytime today shdn't be that crowded.. when compared to weekends ;)
Dellboy
Hi guys, I have two sets of AC66U, one is used for routing and second is used as wirelss bridge. Currently on .270 firmware is everything is good ans stable. Should I upgrade the fw? Any concerns with the latest build on the setup that I have?
chercm
new Merlin firmware -3.0.0.4_374.32_0
My Files
one new stuff : - LED control - put your Dark Knight in Stealth Mode by turning off all LEDs
tt88
Of all the Merlin's Firmwares, which one is the best? I mean stable, no disconnection and with better download/upload speed!
RT-AC66U_3.0.0.4_270.26b or the latest 3.0.0.4_372.34_0?
Elijahonli
help....i using this router...
im getting very slow speeds with wifi connection to the router, most of the time cant even connect to either 2.4 or 5Ghz at all... anyone faced this problem before?
tried flashing back to the normal firmware by asus and setting it up all again but also no use =(
note: the asus router is set to AP mode
lovehikki
Guys,
Need some help from all of you...
Could you all kindly go to this thread and post your results with regards to IPv6?
ASUS RT-N66U & AC66U routers' IPv6 do not work with ViewQwest's
Sample
Product: e.g. ASUS RT-AC66U
Network: Singtel / M1 / StarHub / ViewQwest / MyRepublic / if I'm missing something
Method: Native / Tunnel 6to4, 6in4, 6rd / Static IPv6
Working / Not Working (IPv6 wise)
Thanks!
Background - I have an ASUS RT-AC66U router and a year ago, I gave my feedback to ASUS@SG that the IPv6 component which was specified by them to work, wasn't working. I was told that they will investigate about it and hopefully, have a fix for it... So one year later... the IPv6 component is still broken. I'm looking for ASUS to have the resolution to resolve this problem once and for all, and this time with a deadline.
I don't think by myself, I can make this happen, not by a long shot... so I'm sincerely asking for customers of ASUS who happen to have bought an ASUS RT-N66U, RT-AC56U, RT-AC66U or RT-AC68U router and currently using them for help. That is my plead...
