[Off Topic] The Longest Chit-Chat Thread in HWC - - - - - - - - Part 17
jarred1223
lucky my bmt no laptop no e-learning.. lesser things to take care of, lesser chance to get punishment :s13:
tarui04
What happen to your Mac Pro???
dunno how to start explaining.
the default front panel uses a sata cable and various other cables/wires to power and communicate with the front usb and firewire.
the pinouts are very complicated and to adapt for ATX use, i need to wire a 5v positive wire from the atx 24 pin then ground it thru the usb ports.
the later versions use a 44pin IDE port but the mounting holes are different and the position of the usb ports are off by a few mm.
big enough to notice and block access.
so i spent a long time finding a suitable replacement for that "hole"
1. couldn't find a vertical display OLED/vacuum display
2. eventually settled on a led bargraph to display temps
but more problems. getting arduino, getting the code done because there wasn't a precedence for it so i had to learn basic coding and copy code here and there.
then the led bargraph is not the same size as the front panel holes, so i had to design some plastic adapter pieces to fit and secure it.
1 tiny hole 77x15mm hole give me so much problems.
Mach3.2
I heard Arduino codes are :s22::s22:
ragnarok95
Senior Moderator
Senior Moderator
Lol. The elearning quite fun leh. Learn the ROE then when Sgt kope your rifle when you are asleep, you rifle butt him lol.
Last time my field camp many people also say wah night time sleep if sgt kop rifle can rifle butt him all these sai... but end of the night all drop dead in the tent who still bother? Woke up next day 30% of the platoon fall in one side all kanna. lol
Last time no elearning everything is by mouth and actions... lol
