TheminiGod
- Jul 30, 2013
Hello Everyone, Friends, Auntie uncle Brother and Sister, I need advice on building a new desktop from the scratch. Will buy component in 12/Oct/2013 until then i will keep posting and update.
After doing many research and review on hardware, still don't understand some of few key thing. I will list it out slowly one by one, all you need is to click the link and see the spec, and tell me what to get and best build
Due to lack of posting, I could not link up the link for specifications
will update my post when i have enough right to post and link the motherboard hardware.
GPU of choice preferably Crossfire ATI processor (budget $800)
Gigabtye 7950 $380 per card
MSI R7950 $405 per card
Question:
if my dual graphic card running in x16, would the performers better?
if my dual graphic card running in x8, would the performers drop compare x16?
What else is better then those dual graphic card option above that is within $800 budget can suggest nvidia model?
Motherboard of Choice I7 4770k (buget $675 to $685)
Asus AS Z87-K
Asus AS Z87-Plus
Asus GRYPHONE Z87
GIGABYTE GA-Z87X-D3H
MSI Z87-G45 GAMING
MSI Z87-GD65 GAMING
ASROCK Z87 EXTREME6
After looking at MSI MotherBoard on their website like cool and their feature, is their product speak up to is true, or is appearances can be deceiving
Question:
Which M/B must I take and why?
which M/B best suit for the graphic card, weather is x16 or x8?
Monitor (budget $450 to $500)
Requirement
27"" with IPS screen
I thinking of getting 27"" with support of dual DVI input to max out the resolution of 2560 x 1600
Need advice where to shop and around how much?
Ram: (Budget $250)
2*8gb ram 1600mhz,
Question:
is it worth getting overclock ram?
will overclock increase my FPS and performers alot?
Storage: (budget $300)
2 SSD 128gb
if i use the motherboard on board Intel raid 0, will i have bottle neck?
Case & Power supply, ($200)
Casing and power supply any band will do.
how much Watt do i need for this build?
cos, base on dual 7950 it need at least of 700w, to play safe i get a 850w will it do the job?
Last of all, friend suggested i get all the part at tradepac.
Question:
Asus AS Z87-K
Asus AS Z87-Plus
Asus GRYPHONE Z87
MSI Z87-G45 GAMING
MSI Z87-GD65 GAMING
ASROCK Z87 EXTREME6
Question:
Requirement
Ram: (Budget $250)
2*8gb ram 1600mhz,
Question:
2 SSD 128gb
