The Galaxy Note 3 thread, also stop asking me if it fits in pockets.
NIte_anGEL
can i ask wad SD cards u guys getting n get from where pls? was tihnking to get a 64gb but not sure wad kind to get~ heard alot of sd cards no comparable wif samsung mobiles~
vaxvms
for me only use samsung class 10 for sammy phone in the past
Xerovix
recommend me a good launcher leh.. just one i go try when i am home heh
I just installed Next Launcher 3D full version.... all my screen icons are in all sorts of position and place... very rojak. My friend saw it and thought got serious software corruption. :D
Apparatus
Re
Go into your app drawer inside the Samsung folder.
Samung folder only shows apps like Internet, Voice Recorder, Action Memo, KNOX, Calculator, My Files, Story Album, S Health, Group Play, Samsung Link, WatchON, S Translator, S Voice and Downloads
No My Magazine leh
:s11:
jctj90
anyone encounter the phone will hang then need to wait sometime to back normal?
could you give more details? Like are you switching between apps, booting on and off, or using any particular app? Phone is very smooth on my side so far.
wilflare
is there anyway to prevent changes to the lock screen?
like removing this following screen (+)
Aetherion
I think it's the Multiple Widget option in the Lock Screen Settings.
No My Magazine leh
:s11:
Maybe My Magazine icon only appears when you use third party launcher. If you're using stock TouchWiz, swipe from bottom to up to access it.
wilflare
but if I do that, it removes my DashClock Widget though... :/
those using SwiftKey, are you guys able to swipe down your keyboard?
I can swipe up but I can't swipe down...
Aetherion
Can you replace the default clock widget on the lockscreen with DashClock? On S4 it's possible I think. Then don't need to activate multiple widget on lockscreen.
Zomgnoob
Hey there fellow note 3 users!
Just wanted to drop by and ask about the spen sensitivity.. Does everyones note 3 detect the tap if you use the spen and tap somewhere softly? Mine seems to be unable to sense these lighter taps and i find that the strength i use while tapping seems pretty reasonable. whats more is that does your note 3 also sense a tap action when your spen is tilted abt 40degrees from the screen? mine fails to recognise it sometimes :(
Just wanted to ask this again :) Everybody is a little too busy with their note 3 i guess haha.
