need help on new installation
deepblue_82
now my windows explorer is not working.. coz i am going to upgrade too. mostly getting a SSD..
if i would put the ssd as main a new windows installation.
set my hdd as 2nd.. coz i dont wan to lose all the stuff in there..
would it work?
anything i should look for when i install new a on a ssd?
coz i will be getting new mb cpu ram gfx psu case.. :s11:
sglords
1.unplug ur current hdd, in case u accidentally format/delete ur hdd
2.plug in ur new ssd
3.install os on ssd
4.plug in ur hdd after os is installed
tata. no data will be missing
go download ssd firmware from their respective brand website
disable disk defragment and system restore
deepblue_82
3.install os on ssd
disable disk and restore by windows right? under the drives//?
sglords
yea
disable disk defragmenter
start > type in search > click "disk defragmenter"
turn off schedule
disable system restore
start > click "computer" > right click empty space
click "properties" > click "system protection" > configure C:(system)
disable computer to sleep
start > type in search > click "power option"
click "change advance setting" > set sleep to never > set hdd to never
disable hibernation
start > search "cmd" > type powercfg -h off
deepblue_82
do i need to get any mounting for the ssd ?
i meant for my casing..
MeeHoonGoreng
yea
disable hibernation
Pardon my noobness... how come need to disable computer to sleep and disable hibernation? Will it affect the lifespan of the SSD? Thanks! :D
iKoori
Hibernation need space on ur SSD.
Sleep erm... for HDD users who wants to have a "fast boot up". Sleep uses less power to keep the system at a very inactive mode hence when you wake up the system, it is faster.
SSD just Shut down!
deepblue_82
one last Q..
anyone knows any one who does things like fortan?
go sls buy for me then come my place install..
coz fortan now got back pain. cant..
