[Maylyn's Preview ~ Networking] ASUS RT-AC68U
ASUS@SG
Suspended
Yes its ZXA10 F620GV3.
This is the old type.
Clauswu
Whether old or new type it didn't work with my Asus RT-AC68U. Maybe the ONT is coded in a specific way. Even SingTel technician who was kind enough o help couldn't get it to work when the Asus router was directly connected to ONT.
ASUS@SG
Suspended
Did you setup ur router? Plug & play do not work
Clauswu
Plug and play did not work. Tried a few times with different powering on/off sequence of ONT and router
chunlianghere
new firmware out!
Version 3.0.0.4.374.339
Description ASUS RT-AC68U Firmware version 3.0.0.4.374.339
Added:
1. Added Apple time machine feature in USB application.
2. Both NTFS and HFS+ format HDD are supported.
3. Added OpenVPN server.
4. Added OpenVPN/ PPTP/L2TP client.
5. Some devices like set top box, smart TV or Blu-ray player are not able to establish VPN connection. VPN client in router can help these devices to connect to VPN server.
6. Supported HFS+ format HDD
7. Added 2.4GHz beamforming option in advanced settings —> wireless —>professional
8. Added roaming assistant: allow to set the minimum RSSI to disconnect clients and let clients reconnect to Ap with better signal.
9. Added import CA file and manual edit option in OpenVPN client
10. Added option for tls-auth in OpenVPN server
11. Added private WAN IP checking in VPN server page.
Modified:
1. Enhanced FAT32 read/write speed
2. Modified roaming assistance algorithm for better roaming experience.
Fixed:
1. Fixed OpenVPN server *.ovpn file exporting issue while changed the protocol to TCP.
2. Fixed PPTP VPN client related issues.
3. Applied memory leak patch in media server.
4. Improved the 2.4GHz wireless throughput.
5. Improved the samba throughput while IPv6 enabled.
6. Adjusted 2.4GHz power saving algorithm to fix slow wireless in some special scenarios.
7. Fixed ASMedia 1053E USB 3.0 controller compatibility issue.
8. Fixed IPv6 related issues
9. Fixed quick internet setup UI issues when setup the router by wireless client.
10. Fixed WPS push button related issues.
11. Fixed the security related issues for httpd.
12. LAN user can now connect to OpenVPN server with DDNS name.
13. Fixed IPv6 default route missing issue.
14. Fixed BitTorrent related issues.
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC68U/FW_RT_AC68U_3004374339.zip
stevenang88
Anyone knows it this AC68U supports loopback?
I have the aztech 7002 but it officially does not.
I have a few DDNS setup and need to access it while within the wifi network
Can anyone advise please? Many thanks.
maylyn
maylyn
new firmware out!
Added:
Modified:
Fixed:
Thanks for the update :D
ASUS RT-AC68U users please feedback your experiences with this latest firmware so we can consolidate if there any more outstanding issues before moving forward with more exciting features in the making ;)
mikecjw
Thanks, updated to firmware Version 3.0.0.4.374.339, torrent issue solved.
I will monitor the performance for few more days.:s12:
t258jgn
How to setup
1st WAN port ViewQuest & 2nd 1st Lan Port SingTel (+ 4th Port Mio TV )
siron
Port forwarding always cause my router to lose connection. Been trying a week without any ports forward. And all is well.
Anyone like me?
maylyn
ASUS RT-AC68U router does support NAT loopback without hardware acceleration enabled. ASUS are working together with Broadcom on this issue in regards with the hardware acceleration module that impacting NAT loopback
maylyn
How to setup
It's currently not possible to configure dual WAN for 2x fiber connections on stock firmware at the moment due to the complexity on rules on load balancing (if you are thinking what i'm thinking you are hehe) and different ISP profiles as i was being told, it's still in the works.
Primarily the dual WAN function is to provide a seamless fail-over on 3G/LTE USB modem when one's primary internet connectivity is down (i.e. ISP maintenance, outrages etc) so one can still be connected to the Internet.
Nevertheless it's possible to hook it up on the scenario you have mentioned on experimental test builds :D
I have done it on my ASUS RT-AC56U before :D on my Viewqwest and SingTel Fiber connections
