NOKIA LUMIA 1020
kopi22
Hey, a quick question regarding charging of the phone.
I noticed a strange behavior under the Battery Saver. The phone was fully charged to 100% as indicated, but when I turned off the charger, it is dropped to 94% immediately. So, I turned on the charger again, and it is fully charged to 100% within a while. I think it is impossible to jump from 94% to 100% within few mins.
Battery saving was on though.
Is this normal, or something is wrong with the battery or battery level status indicator? Anyone else experiencing the same thing?
Thanks!
Edited: I think something is not right for the battery status info. It happened again once I off the charger. So, I decided to reboot phone. And the status is reporting 100%, from 94%. Perhaps there is a bug with the battery saver.
satay16
i really regret getting the lumia 1020 black.
should've gotten the yellow one.:(
E_T
Thanks!
Nah, some system process probably hang & report wrong battery level. Reboots usually solves the problem. I doubt it's Battery saver since that should switch off when plugged into USB.
Well Lastbattle is ordering the OEM Yellow back. You can buy from him & change the back to Yellow. :)
satay16
I still want to keep that warranty.:s13:
strange though, i'm not receiving any updates for the firmware. maybe Singapore phones get updated last.
E_T
Or you can do what I did, buy the yellow wireless charger case. Now my White 1020 looks yellow. :)
What firmware? Nokia Black is not scheduled to be released until around New Year 2014.
satay16
this one: Nokia Lumia 1020 receives minor firmware upgrade | WMPoweruser
i brought a clear case for my lumia 1020 already, so can't fit a wireless cover. a point to note for those buying clear cases, if the plastic wraps closely to the lens, you tend to have flaring in dark photos with flash. i presumed the flash illuminated the clear case and refracted the light into the lens.
E_T
My firmware version is 3049.0000.1330.1009. Since it's very close to 3050.000.133x.1010, I wouldn't really worry about it since it could be for Lumia 1020 sold in other markets & we already have the same benefits.
dragonbryan
Hi people, just to check, which facebook client you all using? I using the one by microsoft but it seems like it doesn't update on the tiles.
Another thing, my metrotube wouldn't load when i am on 4G but works fine on WIFI anyone knows why?
Tok Kong
Experiencing same issue with metrotube on mobile data.
So I just use youtube HD lor. :)
pokster
Hi bros, wanting to join the 1020 club and plan maturing soon! Just checking.. i called singtel call centee and they told me different branches have different promo and different freebies... i'm quite shocked tt singtel has totally no consistency...
Need some advice.. where should i get my phone to have better freebies? Or should i wait for comex this coming nov?
Many thanks!
xtrememanix
Many thanks!
there would definitely be better deals and freebies during the comex .
but as long as it comes with the camera grip it should be good enough .
the other freebies are mostly not as important .
pokster
Icic thx bro, cant wait for comex to come!!
From what u see everyone is loving this phone!
satay16
Is the Nokia refocus app available to us yet?
it's available. just downloaded it to use. I can't find it in store from the phone, so had to push it from the website.
amazing piece of software. sadly, no option to save the 41MP file.
