Hi, trying to build a gaming system that can last for at least 3 yrs
ksapple
dun need hdd/ssd/monitor/kb/mouse/odd
budget is 800
need power supply/mobo/processor/GPU/casing/ram
muddle
Well first of all how do you define a gaming pc? If it consists of gtx 780 ti and i7 CPU then your budget is sorely insufficient.
Do take note that in a strictly gaming system, the CPU and gpu are the ones that costs more than the other components.
royfrosty
$800 isn't gonna bring you very far. And the most is gonna be a mid tier GPU that may not be able to handle future games.
Asrock b75m dgs + i5-3350p ~ $271
Adata 1600mhz 8gb ~ $85
Leadtek gtx660 2gb ~ $268
Superflower hx500 500w 80+ gold PSU ~ $89
Shaokoon t28 ~ $87
Total $800. Buy at tradepac. Diy
zenitro
Asrock b75m dgs + i5-3470 ~ $271
Shaokoon t28 ~ $87
isnt
Asrock b75m dgs + i5-3470 ~ $292?
ksapple
willing to up budget abit to around 1k leh ? GPU must able to place ghost mid-hight.
royfrosty
1k
MSI R9 280x 3gb Twin Frozr ~ $435
Superflower hx600 600w 80+ gold PSU ~ $109
Shaokoon t28 ~ $87
Total $987. A high end GPU and a higher PSU included.
Talking about 3-4 tiers higher than the gtx660
Equivalent to a gtx770.
ksapple
1k
Shaokoon t28 ~ $87
hi will the mobo and processor bottle neck the gpu ?
EatSnakeWarrior
Palit Gtx 760 + FSP Raider - 399 / Zotac Gtx 760 + Superflower HX 500 399
Shaokoon t28 ~ $87
prefer 760 over 660
dmg for this is 842
if you incld windows ~ 960 ($120 for os? not sure)
ksapple
Shaokoon t28 ~ $87
prefer 760 over 660
dmg for this is 842
If by nxt ya I were to add 1 mre 760 to sli can ?
m3 th3 last
Roy dont think it need > 500W, some more a 80+ gold version PSU. Whole rig would be pulling max 400w under peak.
voiceoflove
os win8 is great.
overall it has 3% increase performance over win7
i forgot i read where le
ksapple
After some tot is this build advisable?
Asus p8h77v lk + i5 3350p @373
G skill ram 8gb kit@ 99
Palit 760 + psu@ 399
Sharkoon t28@ 87
Os win 7 home 120
royfrosty
Asus p8z99 v le + i5 3350p @373
Sharkoon t28@ 87
Os win 7 home 120
The price you paid can channel to a better gpu like the r9 280x
