iPad mini retina cases covers and accessories
porcu
In this aspect, I will say the Benks "Magic AKR" model is at the same level as the SGP one, i.e. which means it isn't very good at concealing smudges.
That's good to know, though I didn't even realise BodyGuardz made glass sp (I'd always thought they make the wet application film shield thingy only).
Update: woah, the BodyGuardz version for the iPad mini is USD$59.95?!
Adix one quite good. Less smudges on my screen.
ralliart12
Adix one is Clasy brand right? Have you used the SGP one (for iPhone) before? If you have, what will you say about the anti-fingerprint capabilities of the SGP one versus the Clasy one?
jaymessofly
Planning to hoot the adix one soon, will give a review about it after. :s22:
Laneige
Buy AppleCare+ and use your iPad naked.
lol. Anyway, anyone use the $98 Apple smart case?
i am
like it. bought from best denki and choose one among all the displayed lol
because i cannot stand the leather with uneven dyeing or too coarse one else when dirty not easy to take care.
btw those who bought it, keep yr receipt. got 1yr warranty against defect/manufacturing issues?
Matrix21
anywhere sells spigen glas.T for ipad mini retina? seems like most places don't have it. i am using USG tempered glass for my iphone 5 so far so good, so if there is USG ones for ipad mini retina i don't mind too
punker
Hi, is the product red Smart Cover only available online at apple store?
All product red is only available online?
zythen
anybody got a recommendation for a clear or semi transparent case that's value for money that works with the smart cover?
i have read this thread but i still cant find a configuration that i like... thanks!
punker
Few pages infront, there's a bro doing this combi. If I'm not wrong, the back casing is tunewear eggshell or something. Very slim. N he says it works perfectly with the smart cover
njstone9
Does anyone know where you can get the Moshe versacover for the new iPad mini?
I've been all round Singapore looking for it and I can't find it anywhere.
Plus, half the shop assistants have NO IDEA that the new iPad has that extra mic on the back so I can't necessarily use the old mini case!
jaymessofly
Just installed Adix's Clasy a tempered Glass SP. So far so good, will update here after further usage.
zythen
Thanks! I might have missed it cos' someone did mention about a clear case from qoo10 but after reading reviews that the sharp corners scratch the ipad, i'm finding something better.
Anyway, the tunewear eggshell is what im looking for! Thanks for bringing this up!
hLsY
the moshi versacover for mini retina has not been released yet.. the one for ipad mini will not fit.. it stated on moshi website that it will be released late 2013, i doubt you will see it in sg till next yr.. im waiting for it too...
Laneige
didn't see though but i bought mine from Korea. I think about $60 liao. So expensive due to higher WON also Zzzzz. I bought aluminium button too. :D
else its 0.4mm for SP quite thick
either u stick with the jelly button or buy some different design. i think iPad mini works with iPod button. so is diff from iPhone
