Need some advise for a rig upgrade
rucifer
Need some advise from you guys on an upgrade instead of getting an entire new CPU. The reason why i want to upgrade is because my current motherboard network adapter only supports up to 100mbps. I am using Fibre optic 200 mbps.
The motherboard also does not have enough slot for me to plug in a PCI-E soundcard.. currently using Creative Recon3D external sound blaster. Would be interested to get Asus Xonar DX, would it be a big difference in terms of sound?
This is my current setup;
CPU + Mobo: Intel i5-2400 / BIOSTAR H61HLC
RAM: G-Skill HT PC10600/1333mhz 4gb DDR3 x2
HDD: Samsung 1TB SATA 3.5
CD ROM: Sony 24x SATA DVDRW
GFX: SAPPHIRE 1GB 6870 DDR5
PSU: FSP 500W AURUN SERIES GOLD 80+
Casing: COOLERMASTER 370 CASING
OS: WIN 7 ULT 32BIT
Speaker: Altec Lansing MX6021
I will be keeping the HDD and CD ROM and intending to keep casing and PSU if possible. I want to get a SSD for faster bootup, preferably 250GB. Will need to change OS to 64bit as well. My budget for upgrade is about $800.
My usage mainly is for music, tv shows and movies. Gaming not much but im playing games like BF4, currently can only Mid settings.
Appreciate any advice!
LesterQ
Now i have a very good reason to upgrade my rig... :s13:
Hmm even the killer ethernet E2220 is 100mb max.... Or am i wrong?
royfrosty
Take out the network adapter and buy a USB adapter type. Save one pcie slot.
If you are using the fatality Recon it is good enough. You dont need another one.
Might wanna consider 64bit OS as it will utilize the 8gb ram you have. With 32bit you will see 8gb installed but only 4gb usable.
You will need a new gpu if you planning to game on BF4.
TP-Link WN821N 300Mbps Wireless N USB Adapter ~ $29
Windows 7 Home Premium 64bit OEM ~ $115
Crucial m500 240gb ~ $235 or buy at amazon @ $139.90USD
Gigabyte r9 280x 3gb OC 3x Windforce ~ $425.
Total ~ $804 with local m500
Total ~ $750 with US m500
sHrike
I am using AsusN53 usb adapter. connects up to 300mbps unless your router is far away or blocked.u can consider this method.
jiaweiii
Will make it wifi. Will it be slower then the 100mb ethernet..
Depend how far you away from yr modem im using tplink wn8200nd usb high power one bt since im quite far frm modem only hitting 20-30mbps
Edit : yes definately ethernet is always the fastest
LesterQ
Wifi is a strange thing. Even behind one door no distance also can make a difference...
Just wanna ask is there a motherboard with ethernet capable of 300mb?
jiaweiii
Anw why you even need such high internet speed o.o ?
rucifer
Thanks for your advice. I'm actually using the external soundcard not the fatality one. Sound Blaster Recon3D Surround Sound Processor - Creative Technology (Singapore)
If i switched to wireless, will it affect my online gaming? Do i also need to upgrade my PSU if i were to get the GPU you are recommending? Not sure if the power is enough.
m3 th3 last
Err i dun think USB adapter is any good, cause not enough power as compared to PCI version.
Unless to say there is no wall/door in between. Else the connection would be very bad. I had experience twice and thrown them out in flavour of on-board wi-fi. Its alot better.
jiaweiii
A high power usb adapter is better than a normal pci version
LesterQ
I do not see a usb adapter working. That is why i am asking if there is a 300MB ethernet capable board.
Signed up for 300MB ma. Never use then sign for what. :s13:
jiaweiii
True . Look up internet cant find any info bt i believe la most current gen board can support 300mbps
royfrosty
The external soundcard is more than enough.
So far gaming wise not much. Latency slightly higher but no drastic performance decrease.
Many people think that the faster then internet speed = good gaming experience. So everybody go LAN. Yes it is good to a certain extent only. In general, how much of the data is being transferred in actual fact while gaming?
Wireless with the capablity of dual band it can match up to a LAN speed connection also. The only downside is the latency. Probably 1-5% more if you use wireless.
kingsfall
sry to hijack the thread, but just a simple qns. my comp sometimes crash when i load too much video and my screen would just turn black. is it a gtx card, motherboard, cpu,harddisk or ram problem?
im using a gigabyte Z68XP-UD3 motherboard
cpu Processor Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
gtx card is geforce gtx560. latest gtx driver
4gb ram (3.92gb usable)
win7
ive got a 1tb western digital and a 500gb samsung harddisk
thanks alot! :D
jiaweiii
win7
thanks alot! :D
You say you load too much video what do you mean ? Like open too many video at once ?
