Digital TV (DVB T2) in Singapore [consolidated]
Windowlover
Yesterday the skycom technician came to do testing and the reading for the draco antenna is around 42dbi. Then they tested the margon antenna and the reading increased to 70dbi. The signal intensity and signal quality reading all above 90%. Finally it works!
How do you make this arrangement ? I think it is better to check to know before making a purchase.
Marbok_Tan
i just called skycom saying i can't receive any channels using the draco antenna and managed to get them to send a technician to my place to check. they tested both the draco antenna and the margon antenna which they brought along. only the margon antenna works. so i purchased the margon on the spot. there is another bro here that faces the same problem too
btw fairprice xtra is now selling the margon antenna and the draco set top box
pjs
Which branch, pl.
tq
nathan7305
Draco HDT2-7300 STB
Hello,
I bought the Draco HDT2-7300 STB from Fairprice Xtra last week. I used the provided Draco digital amplifier and attached it to a AC/DC 5v adapter. This was followed by connecting the digital amplifier to my outdoor passive UHF antenna. Once done, I did an Auto Scan on the STB and found MediaCorp's 7 DVB-T2 & 4 DVB-T channels. The DVB-T2 channels consist of 4 HD & 3 SD channels. The DVB-T channels consist of 1 HD & 3 SD channels.
The AV quality received is excellent. Finally no snowy and ghost images on FTA!
Now coming to my query, I understand this STB is able to do Timeshift recording. However, I haven't been able to figure that out. The supplied user manual isn't of help either. Could I please have some assistance on this ?
Your assistance on this matter is appreciated.
Nathan
AnDyLe0
Hello,
Nathan
actually u don't have to use any power adapter for the amplifier... just goto Settings on ur Draco stb and turn on "antenna power"... the stb will provide power... no need external adapter.
for the timeshift and pvr functions... just plug in a usb hdd to draco stb and pvr function will be activated.
mrsun18
Hello,
If you are using an outdoor UHF antenna, you should be receiving very good signal. The amplifier is probably not needed. You can verify this by doing a manual scan, channel by channel, for chans 27, 29, 31, 38 and the latest test transmission on chan 33. Note the signal intensity and signal quality for the different channels with and without amplifier.
Amplifier can increase signal strenght but at the expense of signal quality. This is because the amplifier itself adds noises (=<3db according to specs) to the amplified signal.
Nathan
As pointed out by AnDyLe0, just plug in a usb hdd and you are on the way. Thumb drive, card reader with SD card or equivalent also can.
However, if you are still stumped after an external drive is attached... the quick answer is the "pause" button on the remote will start the time shift function. To resume, press the "play" button.
sunsetbay
Moderator
Moderator
So guys, I ask a question:
So far, are there any PC tuner cards that are DVB-T2 v1.3.1 compliant that allows one to watch TV or record TV to watch later?
i think this maybe the very one tat work in Sg~ checked cybermind pricelist, its $149~ more ex than the draco STB~
PCTV nanostick T2
harky
i need one
PCi that are DVB-T2 that can see tv, record tv, and also has S-Video and composite inputs to capture from other video sources
harky
do u own this? may i know how to connect from cable box to usb ah??
use tv cable ah??
AVerTV Hybrid Volar T2
it's a usb stick, jus released in august 2013. I'd believe it is 1.3.1 compliant since 1.3.1 is published in nov 2011.
PoloBoiBoi
PCTV nanostick T2
but then looking at this ...
After many queries by peeps i built HTPCs for, an update by Hauppague Singapore on the locally available Nanostick-T2. Summary/takeaway : await updated version that is v 1.3.1 and compatible with local channels (scheduled to be out Jan 2014)^^
don't think so leh ...
seehong
Hello,
Nathan
To do timeshift recording, just go to the menu and select timer setting. From there choose Record, Channel, and your time of recording. I have done it. The only setback is that while recording is on, you can only watch one other channel which is fixed by the STB and not one of your choice unless you choose to watch from your own TV tuner instead of the tuner on the STB.
matrix05
How is the outdoor and indoor reception at Punggol?
With a built-in DVT2 TV, do I need to buy the margon antenna or can use existing HDB antenna?
