MSI GS70 Stealth Review
PC_Dreams
Featured Distributor for Notebook Clinic
just wondering,
since the laptop has no cd drive
if windows go siao or what, how?
You can always create a Windows 8 recovery partition on an external harddisk and recover from there.
Windows 8 allows recovery creation on Disc, local drive and external drive. :)
tidiii
If you need a drive you could plug in external DVD drive?
okay....but why would i have an external dvd drive when 99.9999999999% of pc and laptop have an internal cd drive..
what i meant was is there any alternative where i can save/recover my pc without a cd drive
ty, another question
when i bought the laptop, the ppl told me to charge it for 8hours first
but when i brought it home and charged it, the charger turned itself off after it charged finish
so how do i charge it for 8hours/ do i need to charge it for 8hours?
chiaRH
This laptop happened to be part of the 0.0000000001% of laptop/PC that does not have an internal drive. It's the same thing for people who buy laptops like the Razer Blade or the retina macbook pro, they also have no internal optical drive and need to buy an external one.
As mentioned by pc_dreams you can do recovery partitions on an external source
tidiii
razor blade no cd drive also????????wtf???????
anyway does anyone know how to turn off the bluetooth?
i dont use bluetooth so i dont want to keep it on incase it connects to some random people device or they link up to my pc
PC_Dreams
To your first question, solution already provided. Instead of creating a recovery disc, create a recovery partition on an external harddisk.
To your 2nd question, no need to charge 8 hours. Just charge to full will do. Charging 8 hours is a standard phrase to use so as consumers will charge their devices to full battery no matter which laptop or phone/tablet they buy. :)
By the way, more than 25% of laptops sold do not have DVDRW drive now. If you total the numbers of laptop + tablet, then more than 60% of devices now do not have DVDRW drive. :)
PC_Dreams
Under pc settings from the right hand Chimes bar (slide out menu), look for "PC and devices" menu option. That will allow you to turn on and off bluetooth.
But actually it is ok to leave it on.
1) Random people cannot connect to your laptop unless you paired it with a passcode. If you do not want to broadcast your bluetooth, you can turn off the discovery mode.
2) Bluetooth 4.0 is actually very low powered, thus it does not really drain your battery life. So it is pretty ok to leave it on.
tidiii
pair with passcode? so must put password on my laptop bluetooth?
chiaRH
pair with passcode is when a bluetooth device wants to pair with your laptop, usually a 4-digit passcode appears on both devices and you need to verify before the devices will pair.
tidiii
thanks
another questions,
anyone have had a chance to have long gaming sessions with the laptop yet?
any overheating issues?
porcu
my longest session is like an hour per go. So far no heating issues. :)
Playing MGS , Assassin Creed 4 now. Cool laptop :)
evq
Sad till now I still having game on it. Been using my pc instead of this
watzup_ken
Personally, I don't recommend installing from CD as its very slow. Normally, I keep a copy of the OS on a thumb drive, and will install from it directly. The DVD rom is probably the slowest device on a PC so far.
evq
Btw is the bluetooth issue solved for wind 8.1?
tidiii
anyone know how to turn off the logo?
i want to save as much batt as possible
i used the SCM to turn off bluetooth
turn off keyboard backlight also
webcam off
wwwvictoriskingcom
anybody have problems with the hdmi port tried connecting to tv and projecting duplicate screen but can't work samsung tv any help would be appreciated or is there a way to test whether hdmi port is working?
reonu5142
Problems with wifi card
I got my GS70 for about 3 weeks and all is a blast but recently I had to do system recovery because my wifi was suddenly dead, as in I couldn't switch it on as it is not even highlighted, anyone has similar experiences?
PC_Dreams
Did you happen to upgrade to Win 8.1?
Rexter
i using this as gaming plus work. So it will be use for long hour so thinking of getting one haha
