Digital TV (DVB T2) in Singapore [consolidated]
singpal
Hallo guys. i am able to receiver ALL Digital Channels such as HD5 , HD8 , HD Suria , HD Vas , CNA, Okto and channel U via Draco SET TOP BOX in Batam Indonesia.currently i have 3 receivers for testing and the results are great. I use my Outdoor Antenna face to Singapore. I can get the strenght signal (92%). Firstly i bought Getmecom in jakarta, it supports DVB t2 indonesia and DVB t1 singapore due to getmecom demulator msb 1230 (not support 1.3.1) and then i bought draco in singapore at best vivo. Viola... get all the HDs. and the last i have a dvb t2 brand mpeg4 made in china, it works also. i also sell dvb t2 receiver made from china (support singapore standard 1.3.1) in batam and price S$60 per unit. for 2 units S$110 only.
is yrs getmecom hd9? a guy managed to use hd9 successfully here in Singapore btw ;-)
chakuman
Ok guys an update from what I see from my StarHub HD box (I am using Hubstation HD)
Channel 116 Suria HD - Keeps switching on and off
Channel 154 Ch8 HD - Black screen
Channel 155 Ch5 HD - Working well as always
Channel 156 Vasantham HD - Channel locked but can hear the audio
kenny cheung
the Getmecom firmware starts from 2012 dec - march 2013 unable to receive dvb t2 1.3.1., i have already rechecked the pcb board inside getmecom , the serial number on the board is MSD7816_T02_V1.1_120718 and modolutor chip is MSB1230. the firmware version: December 2012. :s13:
before you buy this brand , you must check the latest version of pcb board or firmware. if you dont believe , i sell my getmecom S$ 20 to you :s13:
singpal
oic, so there are two different hardware version of getmecom hd9, when u bot the getmecom? early last year or recently?
u got sell new ver getmecom hd9?
singpal
They are using a delivery service called "ComOne Express".
your user interface looks exactly like the one in truly asia forum? if the same then it is using mstar msd7816 chipset,heard they don't use ali chipset anymore :-D
mrsun18
Only 2 out of the 3 audio channels sound.
1 is the non-surround sound, the other is the surround sound.
Sound quality is good.
thanks for the info. my stb also has this problem of playing audio 1 by default when switch channels,since the machine cant decode audio one of hd channels thus have to change audio channel like u. but mine for hd channels,only the second audio has sound but sound muffled, so yours stb seems to be a better choice;-)
The audio has 3 streams. One of them could be a dummy, ie with audio info displayed but with zero sound (muted). When I record HD program with Draco and playback on pc using VLC media player, I can choose to play from any one of the three steams. The second one always has no audio.
Edit: Watching HD on Tv with Draco produce no sound from second stream.
kenny cheung
sorry for that. i dont sell getmecom due to failed to receive mediacorp t2 channels. i am not sure if the other getmecom still able to receive mediacorp t2 signals, mine not working properly. my getmecom version is "dec 2012". i only sell mpe4 dvb t2 brand.
singpal
thanks for yr valuable info:-D
singpal
Yes. Will post some other eccentric behaviour of Draco when I have more time.
looking forward to yr review of draco ;-)
for my stb, the test channels sound crisp n clear,only the 7 fta channels sounds muffled, hopefully the one with no sound channel on hd channels will be replaced by the audio format using on the test channels now ;-)
