Now I see Suria HD is on StarHub Channel 116.
Can u share the raw frequencies of StarHub Channel 114 and 116? I know Ch5 HD in StarHub Channel 115 is 370Mhz.
Hallo guys. i am able to receiver ALL Digital Channels such as HD5 , HD8 , HD Suria , HD Vas , CNA, Okto and channel U via Draco SET TOP BOX in Batam Indonesia.currently i have 3 receivers for testing and the results are great. I use my Outdoor Antenna face to Singapore. I can get the strenght signal (92%). Firstly i bought Getmecom in jakarta, it supports DVB t2 indonesia and DVB t1 singapore due to getmecom demulator msb 1230 (not support 1.3.1) and then i bought draco in singapore at best vivo. Viola... get all the HDs. and the last i have a dvb t2 brand mpeg4 made in china, it works also. i also sell dvb t2 receiver made from china (support singapore standard 1.3.1) in batam and price S$60 per unit. for 2 units S$110 only.
can only go batam to buy from u?
is yrs getmecom hd9? a guy managed to use hd9 successfully here in Singapore btw ;-)
the Getmecom firmware starts from 2012 dec - march 2013 unable to receive dvb t2 1.3.1., i have already rechecked the pcb board inside getmecom , the serial number on the board is MSD7816_T02_V1.1_120718 and modolutor chip is MSB1230. the firmware version: December 2012.
before you buy this brand , you must check the latest version of pcb board or firmware. if you dont believe , i sell my getmecom S$ 20 to you![]()
Within 5 days! arni...express...Btw I received this tuner liao.
your user interface looks exactly like the one in truly asia forum? if the same then it is using mstar msd7816 chipset,heard they don't use ali chipset anymore :-DThey are using a delivery service called "ComOne Express".
Only 2 out of the 3 audio channels sound.
1 is the non-surround sound, the other is the surround sound.
Sound quality is good.
Thanks for the info. Me using Hokkien speakThey are using a delivery service called "ComOne Express".
but those DVBT2 tv and draco stb will have sound for all 3 audio channels, maybe i wrong :-Dthen what's the 3rd for?
Every time.![]()
The audio has 3 streams. One of them could be a dummy, ie with audio info displayed but with zero sound (muted). When I record HD program with Draco and playback on pc using VLC media player, I can choose to play from any one of the three steams. The second one always has no audio.thanks for the info. my stb also has this problem of playing audio 1 by default when switch channels,since the machine cant decode audio one of hd channels thus have to change audio channel like u. but mine for hd channels,only the second audio has sound but sound muffled, so yours stb seems to be a better choice;-)
oic, so there are two different hardware version of getmecom hd9, when u bot the getmecom? early last year or recently?
u got sell new ver getmecom hd9?
Yes. Will post some other eccentric behaviour of Draco when I have more time.thanks , so even on draco,there will be one audio no sound for HD5?
thanks for yr valuable info:-DThe audio has 3 streams. One of them could be a dummy, ie with audio info displayed but with zero sound (muted). When I record HD program with Draco and playback on pc using VLC media player, I can choose to play from any one of the three steams. The second one always has no audio.
Edit: Watching HD on Tv with Draco produce no sound from second stream.
