NeonX
- Jan 1, 2000
Android OTA updates are rolled out in waves. If you don't get in the first wave, then no matter how many times you press the update button, you won't get the update. You'll have to wait for the second or third wave. The surefire way to get the update is to use Kies 3.
can't upgrade with kies also, says GALAXY Note3 (SM-N9005) does not support
