Need advice on upgrading PC
maayub15
UPDATES:
MANAGED TO BUILD A NEW RIG. SEE ON THE SIDES>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
TOTAL DAMAGE: $780(PC) + $199(23" MONITOR) + $29(PROLINK WIRELESS KB N MSE) + $49(CREATIVE HD 720P WEBCAM)
Hi to all,
need your advice on suggestion to get a new rig.
my requirements:
- preferably to have usb 3 support
- would want to salvage my gfx(xfx 5770), wd blue 500 gb hdd, andyson g530 psu
- want to use wireless mouse & KB( want to cut down on wires!!!)
- rig needed to support d3 kinda games, videochat, browsing etc
- don't OC components
Proposed build(based on price availability from sls pricelists):
Asus H81m-a with i5 4570 $317(tradepac)
g skill DDR3 8gb $95 (bizgram)
samsung 24x dvdrw $21(tradepac)
crucial m500 240gb $215 (pc themes)
sharkoon rex 3 $69(tradepac)
win 7 pro $175 (cashtronic)
dell 2340L $235 (bizgram)
logitech mk220 $25 (tradepac)
total: $1152
concerns:
- would my existing psu support the components?
- better to get ssd on amazon(samsung pro ssd 240gb <$190) instead due to lower price?
- any better components to replace those in the build for similar price point?
Would also consider other proposals for the build preferably within $1k budget.
Thanks in advance for all your advice!;)
royfrosty
Is best for you to start from scratch. The pc is not worth upgrading.
jtjt00
Only the HP DVDRW can be reused.
Get SSD instead of HDD for OS drive.
maayub15
Looks like I'll be replacing the DVD drive too... Btw, any suggestions on the build for the new pc?
maayub15
Most likely I'll be keeping the gfx and hdd if the new rig... Might consider putting in a SSD as suggested for the is boot and use the ide one for storage etc.
royfrosty
Ide is not worth using le. Even with adapter. Furthermore i believe your dvd and hdd all not even sata connections.
Basically just buy new ones. Dvd drive now $21 only. Plus hdd 1tb $76.
State your budget including a monitor. So that we can help you further.
maayub15
looks like i have a new 500gb sata hdd while clearing my drawer. I'm looking for about <$500 for cpu+mobo+ram+ssd. i'll use back my existing monitor, gfx and get a 2nd hand dvd writer. Thanks for the help so far royfrosty,shadow84 n jtjt00
shadow84
$500 for a rig that supports diablo 3? Very hard..... summorr wan include ssd.
alamin2
Asrock H81m-HDS with i5 4570 $338
G.Skill 8gb $94
Adata 128gb SSD $128
$560
id buy a new one if i were you... dvdrw are cheap now.. and you never know the lifespan that 2nd one has ..
maayub15
i'm guessing my chassis should be able to hold either atx or matx mobos... as for the ssd, would it make big difference on operations between the various models/brands?
alamin2
Cant answer ur qn for ssd as i dun use it.. However ur casing is mid tower so both atx and matx can fit. The h81m is matx
Hailgod
Doesn't matter too much what ssd u use. As long as its an ssd, it will be awesome. I have a samung 840pro amazon set. got it when it was only 189usd and its great.
maayub15
btw, can i know if there is such a thing as pci card that has usb 3.0 ports?
i've seen a few pcie types but not for pci...am thinking of adding usb 3.0 ports to my chassis and preferably try access them from the front rather than at the back....perhaps similar to the "chassis fan control module" type..
shadow84
No such thing.. No one would bother to mix old tech with new tech. PCIe is for the back, not front. Coz it will give u usb3.0 ports, similar to rear i/o.
muddle
Yes pci usb3 card exists Newegg.ca - Koutech 2-Port SuperSpeed USB 3.0 PCI Card Model IO-PU230
Take note it will probably clog the bus bandwidth when using high speed devices simultaneously.
Oh, another thing mr shadow, here is a pcie card for additional front panel headers
http://amzn.com/B007SJGGAE
There are numerous others in amazon if only you willing to search.
