[Off Topic] The Longest Chit-Chat Thread in HWC - - - - - - - - Part 17
shadow84
i see ppl talk about earphones :crazy:
i have no problems spending 800-900 on graphic cards, systems, top of the range ssds, power supplies, etc
but i have issues with spending $80 on earphones :s34:
If a $50 earpiece pleases u, then so be it lor... lol
tarui04
half the time i am listening to movies/tv or game
so those wont sound worse on it...:s13:
my earphones are the free ones that accompanied my media player
cyberwave
Saw u got EK backplate for 290x. Can it fit with other waterblocks? Thinking of getting heatkiller gpu block for 290/290x and EK / XPSC backplate. Does the holes line up, based on pics?
the holes should line up. since screws go thru the pcb holes.
but whether the screws provided are of the same threading i do not know.
also there will be some holes without threads since the heatkiller block is not full length
tarui04
existing backplate cannot use or reference cards no have backplate?
shadow84
if can use back msi backplate, i dun mind.. but holes seem to be lesser. Haven go n compare yet.
Summore msi backplate gt a hole whereas gpu block bo hole for core.
koicafex
eh play half way my PSU started making sound leh
sibei noisy
think the fan chipped or something got in...
nvm...i took it out
shake shake
put back no more sound liao...
