Huawei Honor U8860 non camera Users come in
Imperado
Imperado
Okay i have rooted successfully and verified that rooting is a success.
From what I read, most of the ROMs are for the camera honor? Will it have a problem when we flash our non-cam to those ROMs?
foxbat
Shouldn't be. I did before. No harm.
The camera app will just show up but will give an error msg if u try to activate it. Rather obvious as there is no camera to be activated.
End of day.. won't harm anything
Imperado
ahh alright, that sounds good. thanks!
zhaoshanhe
hi all,
tried to do the MIUI rom then says update failed. so downloaded some shuaime software and not, my phone got this image verification failed thing. i cant enter home screen at all. when power up with both volume buttons pressed, only get pink screen. connect to computer, cant detect usb. any recourse?
any help is much appreciated.
thanks
foxbat
hi all,
thanks
Hmmm... I followed the Xiaomi MIUI rom guide to the letter. No problem.
The only difference I did was at "Replacing Recovery" step 3. Instead of holding down the VOLUME DOWN and VOLUME UP buttons, I held down Volume up and power buttons.
Perhaps u may want to retry.
Imperado
foxbat
Yes! Succeeded in rooting and changing to MIUI interface
To help others:
I used the following website -
shadowandy – my life stories - Huawei Honor U8860 Did their step 1 to 3 with their programs
Huawei U8860 Honor / Honour / Glory - Index - xda-developers Referred to here when I dont know what button to press haha
MIUI Official Community Follow this step here for the MIUI zip after the first URL step 3
Please dont forget to backup your recovery.img file before u replace them =)
Cool.
Can check if whatsapp can work?
I can't get whatsapp to work although can install!! :s22:
zhaoshanhe
hi bro,
thanks for posting the 1st url. definitely helped alot and successfully rooted and changed to MIUI interface!!
To help others:
Hi, i have jus verified and used whatsapp on this phone so maybe u want to send an email to whatsapp support for assistance? i tink they will recommend u to download and install the apk from their mobile website.
Cool.
Imperado
hi bro,
No problem! Congrats!
foxbat
hi bro,
Ok I'll try
kitboi
touch screen not working
for those who experienced their touch screen malfunctioning.. how long did it took for the service center to fix it? what are the charges?
OR did u managed to fix it yrself?
ivana833
Android 4.4.2
forum.xda-developers.com/showthread.php?t=2648757
Get the best for this single core phone.
Smooth rom, great battery life, updated
qyc_91
MIUI
While it looks pretty amazing, running MIUI only leaves you with little ram left.
I would prefer rom like slimbean/beanstalk that are really light on ram.
lillitmus
hi shanhe, I got stuck at the same steps as you did.
are to share how you overcame it?
zhaoshanhe
hi lilitmus, i follow Imperado's post #1221 using the shadowandy method. cant exactly recall the steps i took but i tink you read thru the first 2 url and then do some trial and error.
hope it helps.
chopra
does anyone have an answer to this?
