galliano
- Sep 28, 2001
Allcast, now, via ChromeCast, is able to cast photos, videos, etc from your Android device to the TV. ChromeCast is getting better by the day!
What about Apple?
For those who are using DNS based VPN (MR teleport/Unlocator...), besides the iptables workaround, there is another method to cast Netflix.
Basically, you need to set up a static route for the Google DNS so that it will result in host unreachable and Chromecast will use your DHCP DNS. I've tried it on MR teleport and I am able to cast Netflix now. This method is easier and it will still work after router is rebooted. These are my settings for static route on Asus RT56U:
8.8.8.0 255.255.255.0 192.168.1.250 1 LAN
8.8.4.0 255.255.255.0 192.168.1.250 1 LAN
Please read the last few pages in the XDA thread to understand more.
V frustratingand limited apps out of the box.
In the end,i just bought apple tv and mirror my ipad.
Anyone using Plex for Chromecast? Does it work in Sg? How does it work? Does it talk directly to the Plex media server or you still need an android device somewhere and then cast it?
Thanks in advance.
can apple tv stream videos + srt/pics/music directly from nas?
I've tried Plex using Chromecast over the weekends. For Synology NAS user, you can also use Chromecast via DS Video, very similar to Plex. Advantage is that DS video is free while Plex client is not.
For Plex/DS video and all chromecast compatible apps, you need to control it with your phone or tablet. In Plex app on phone/tablet, navigate to the media, click on the chromecast icon and select your chromecast device, then press play.
Hi, you mean that, with Synology and Chromecast, can directly play video on my TV? Does DS support RMVB format?
Yes, with Synology and Chromecast, you can play videos from your NAS directly on TV. You need to install Video Station package on your Synology and DS video app on your phone/tablet. One more thing, you will need to update Synology DSM to version 5.0 to be able to use chromecast.
In my own testing, it is able to play most files, however there are some that doesn't work. I didn't test with rmvb, you might want to check this Can my Synology NAS transcode videos for my device? - Synology - Network Attached Storage (NAS). If your NAS model is able to transcode rmvb, then it should be able to play.
I keep having buffering issues with plex on Chromecast for 1080p movies,.. 720p is fine...
Mmm. Will test RMVB later
Update: Test RMVB. It works with Plex and Chromecast. Able to play the RMVB file on my iPhone and then cast onto the TV with Chromecast. My Synology is DS1813+.
