Sony Xperia Z2 - Sirius-ly A Good Phone
casshern
point 1 ok reasonable
point 2 erm i talking about using app to determine, not "feeling" it lah
how hot is ur hot?
i have Xposed TempCPU on my Z, usual normal temp is 37degrees to 39degrees.
only time it has went below 30degrees is i slept with aircon on and i wake up in the morning
MysteryNotes
75 fahrenheit? Got phone can reach 75 celsius? :eek:
No, 75 degrees Celsius. I double checked my CPU temperature with System Tuner on that phone. The back of the phone has a protruding camera as well, and it's metal. When I touch it at those times, I can feel how hot it is.
WoAiGuiGui
how hot is ur hot?
i not really using my z2 yet
but 3mins of simple usage(means no flash no playing game) quickly raise temp to 34 is considered on the higher side when compared to other android phone i use
i suppose the no ventilation theory makes a lot of sense for the slightly raise temp for all activity across the board
HikarU123456
let me tell u why it feels hotter.
1. Waterproof phone with sealing all around. Heat dissemination is definitely lower that conventional phones since there's lower level of ventilation
2. Glass back is a conductor of heat, hence u feel it more than those plastics.
i din noe that the z2 back is made of glass leh? i tot is plastic? lol
WoAiGuiGui
browsing with chrome can hit 75 that is really wow... maybe ur htc one is faulty
for me i play game with socket charger plugin also 50++ and doesn't go any higher
casshern
34 degrees is fine.
My Z normal operating temp as i stated about is about 35 to 39, screen on with just scrolling of menu, settings, whatsapp etc with no intensive activity
casshern
Sony Xperia Z2 now available in Singapore - CNET
The all-glass front and back Xperia Z2 comes powered by a quad-core 2.3GHz Qualcomm Snapdragon 801 processor and runs Android KitKat (4.4.2).
Sony Xperia Z2 Review: First Impressions - StarHub Community - 72263
Following the same design blueprint as earlier Xperia Z models, the Z2 has a glass panel on both front and back.
boyfunsg
another observation of mine, not sure why:
Whatapp messages and emails that come in via auto push do not show if my phone is in lock screen inactive condition. only after I unlocked the phone, msg and notification starts to pop up. Looking at the timing indicated, those replies were sent sometimes ago...how ahh
WoAiGuiGui
u are using stamina mode
whitelist as needed
Dixon.
After fiddling for a while,
Finally figured how to move downloaded songs from phone to sd card for z2.
