1.The analogue signal from HDB's matv point is supposed to be as good as that coming from SCV point.
Call HDB Branch Service Line : 1800-2255432 (Weekdays: 8.00am - 5.00pm)
Explain the problem and they will rectify for you.
2. You did not say whether you were able to receive analogue Chan u, Octo and CNA from the matv point. If you can see these channels then your chances of getting digital dvb-t2 is pretty good. In that case you won't need a separate antenna for the digital tv reception. Keep your finger crossed![]()
On my crt tv i connect to matv . My ch 8 & 5 signal is not acceptable therefore i did not search for other. I found that the matv connector quite rusty or oxidize not sure HDB will change it for free.
Now hook up to my new TV to scv point was all good but can't receive any digital signal. Image was acceptable.
Will call HDB see if they can rectify the problem.
Some can receive digital signal thru Daiyo HD Digital Indoor Antenna EU1702 and Margon Combo 5.1 . Not sure if i want to invest on this as my purchase of the $12 indoor antenna fail badly. Any advice. Thanks
