Sony Xperia Z2 - Sirius-ly A Good Phone
XasakuraX
how is it short?
after 15 secs then cut off?
not sure abt length, but my ringtone front opening havent even finish then call end liao :s13:
If you set when busy and divert to your voicemail then the ringing will be short compared to no divert to voicemail.
ehhhh isit... shyt... where to disable the voicemail? didnt seem to find it :/
no wonder so short...
ok managed to update to .69
btw are we ablet o choose default storage as the sd card instead of internal memeory ?
app2sd function? interested to know too, if have, cos i tot kitkat disable tt...:s11:
kev_lim
Wanna check is anyone facing this phone the whatsapp/line or sms to be receive like lag about delay 10mins?
enriqueyang
!!!! you win liao.. i searched in xda so hard for "THE FRY" and now turn out to be a typo. well done!:s13:
ok please upload the ftf, can also advise after, how do i update the firmware?
Thanks!
i got the ftf le, hwo to update?
zolachen
i'm facing problems in connecting with my home wifi. Any solutions? After keying the password for the wifi, it just saved but not connecting to the network.
Extremme
Is this a wide spread issue? I saw a few complaints on this too.
maumu
yes it will log the data after you connect back the phone it will hold it on the memory and will sync it once you connect back
serious?? I was told by Sony people need to carry the phone along... so the band has own GPS function?
anirudhks
to be in all fairness , why would you need to carry phone all the time coz , if you carry phone , phone it self can count steps no need of this device, the device would be useless then coz its only job is to count steps .. read the user manual online it clearly says if u get disconected from the phone , the memory on the device will keep track of the steps and the it will sync..
Ohayo!
latest is 17.1.A.2.55 right?
just got it from telco seems its updated already
