XasakuraX
- Feb 26, 2008
how is it short?
after 15 secs then cut off?
not sure abt length, but my ringtone front opening havent even finish then call end liao
If you set when busy and divert to your voicemail then the ringing will be short compared to no divert to voicemail.
ehhhh isit... shyt... where to disable the voicemail? didnt seem to find it :/
no wonder so short...
ok managed to update to .69
btw are we ablet o choose default storage as the sd card instead of internal memeory ?
app2sd function? interested to know too, if have, cos i tot kitkat disable tt...
