Digital TV (DVB T2) in Singapore [consolidated]
clintonccy
DVB-C: HD5, and all other digital channels like Ch8, U, CNA and so on.
Do you know if the DVB-C permanent or will it be switched off at some future point of time? I just need to get my desktop connected to the TV at home, SCV point and not being portable is not a problem for me.
wwh5210
DVB-C will be switch off in the future if I'm not wrong.
b00mxer
DVB-C like DVB-T/T2 are the next generation of TV format. No it will not be switched off anytime soon yet. DVB-C just launched not too long ago. At most starhub will move to DVB-C2 in the near future.
tan1688
everything is fine, video is good. except the sound, which sounded the same as one of the users who posted earlier on. its like the pitch has been increased. funny thing is the dvb t HD5 sounds better than the dvb t2 HD5
Is yours a defective unit for the sound ?
I bought quite many units and have shipped back quite a lot of defective units back, sound unclear, hdmi not working, firmware unable to decode sg dvbt2 transmission, digital output not working etc problems to direct manufacturer. I ship back to manufacturer costs is already ~20sgd per unit not counting ship back to sg costs again.
Could consider getting from me as i test all units guaranteed working before delivery, no risk of defective units, provide 1to1 exchange or refund if there is problems within 1-2weeks of delivery. Kindly see my thread here. :s12:
Ya. Same here. The first two options got sound but the last one has no sound at all(the one with DD logo). The video quality is great but the subtitles are not sharp and the sound are not as solid as the normal DVB-C(I used HD5 to compare).
Hi bro, thanks for getting the unit from me:). For the "the sound are not as solid as the normal DVB-C" did you test with digital output as raw HDMI or PCM or using the Analog Left(white) and Right(Red) Audio outputs ?
I tested with HDMI and sound was same as DVB-T on another TV. Glad that you are satisfied with the video quality, Kindly help me to introduce to your friends if they are looking for one.
wwh5210
I'm using HDMI for the connection and the sound is not as solid as / as clear as the DVB-C one.
sunsetbay
Moderator
Moderator
DVB-C was here long ago when starhub started using digital STB~ :s22:
matrix05
tan1688
petetherock
Moderator
Moderator
Guys
Just a reminder to keep the talk to technical stuff and sharing of sources of STB.
For antennas, there's a separate thread and likewise for settings.
As for sales & MO chats, keep that out of this forum.
Thank you, cheers.
khonghinglee
Check with your guys, I just bought my new TV a few months ago. Read from the specs that it supports analog, DVB-C and DVB-T, but not DVB-T2. I connect it directly to the Starhub cable point, no STB. It can receive all the digital FTA channels including HD5. I understand DVB-T2 does not apply to cable, so does that mean that even in the future I need not use DVB-T2 since I am already using DVB-C anyway? Even when they cease analog and DVB-T transmission?
hwsinn
Yes, indeed it works. Because the cables are not stiff, I have to use scotch tape to hold down the black and red cables to form the "T" on a wooden ruler.
Below are the results, using Draco stb:
  • Chan 27 >90/98 (Signal Intensity/Pic Quality)
  • Chan 29 >90/98
  • Chan 31 >90/98
  • Chan 33 >90/98
  • Chan 38 ~90/98
:s12:
Thanks alot bro! Now all i need is to go and buy the correct connector head and DIY!
hwsinn
If you do not have pay tv then you can use dvb-c or t or t2.
For c you just need to connect to scv point.
For T and T2 its over the air so u just need to connect to a normal antenna
I would recommend using C or T2 as T only have SD8, SD5, SD CNA and HD5
I do not know when they will cease T transmission though. But even they do cease C transmission they surely will replace it (if not how cable tv can be transmitted to users). But if they cease C then u have left with T2 :)
Hope i didnt confuse you further :s22:
sunsetbay
Moderator
Moderator
existing analog terrestrial & dvb-t transmission will be here for another 2 years, they may or may not extend the deadline~
DVB-C is not part of this switch over exercise as starhub own the cable infrastructure~ whether starhub will continue to use analog cable & DVB-C or upgrade to DVB-C2, only starhub will know~
why not just wait until the day come, there's no hurry to get prepare now~ :s22:
b00mxer
To future proof your TV, get your TV connected to either the T2 or C signal.
As for DVB-T (first gen) doubt they'll cease the signal, it will prolly go on alongside T2 just that there are limited channels.
Analog is confirm to go off by 2020. The official way is to be connected to T2 infrastructure. If not DVB-C.
DVB-T/T2/C will be here to stay. Except analog transmissions.
tatsit
High Honorary Member
heres a short clip. notice the sound, kinda like low quality audio streams which you will get from 987fm online
https://www.dropbox.com/s/qsquluc0nms6xhq/Ch_5_(HD)-05082014-2030.mts
there are 3 audio streams in the video file, first is acc 5.1 is a bit choppy, second is acc stereo (which i suppose is 2.0 or 2.1), last is eac3 5.1. i've no idea which one cant be heard on TV, but all 3 sounds have the low quality problem
