133RMB
³§¼Ò¹©Ó¦DVB-T2 MPEG4/H.264 DVB-T2 ÂíÀ´Î÷ÑÇÄϲ¿ ÐÂ¼ÓÆÂ 2014°æ
btw, HD5 has 3 audio channels, what is the mpeg channel? that has no sound
wah swee swee
133RMB
DVB-C: HD5, and all other digital channels like Ch8, U, CNA and so on.
Do you know if the DVB-C permanent or will it be switched off at some future point of time? I just need to get my desktop connected to the TV at home, SCV point and not being portable is not a problem for me.
DVB-C will be switch off in the future if I'm not wrong.
i'll try to find an external hdd so that i can post a short clipLooks good. Can take the trouble to give a short review?
everything is fine, video is good. except the sound, which sounded the same as one of the users who posted earlier on. its like the pitch has been increased. funny thing is the dvb t HD5 sounds better than the dvb t2 HD5
Ya. Same here. The first two options got sound but the last one has no sound at all(the one with DD logo). The video quality is great but the subtitles are not sharp and the sound are not as solid as the normal DVB-C(I used HD5 to compare).
I'm using HDMI for the connection and the sound is not as solid as / as clear as the DVB-C one.Is yours a defective unit for the sound ?
I bought quite many units and have shipped back quite a lot of defective units back, sound unclear, hdmi not working, firmware unable to decode sg dvbt2 transmission, digital output not working etc problems to direct manufacturer. I ship back to manufacturer costs is already ~20sgd per unit not counting ship back to sg costs again.
Could consider getting from me as i test all units guaranteed working before delivery, no risk of defective units, provide 1to1 exchange or refund if there is problems within 1-2weeks of delivery. Kindly see my thread here.
Hi bro, thanks for getting the unit from me. For the "the sound are not as solid as the normal DVB-C" did you test with digital output as raw HDMI or PCM or using the Analog Left(white) and Right(Red) Audio outputs ?
I tested with HDMI and sound was same as DVB-T on another TV. Glad that you are satisfied with the video quality, Kindly help me to introduce to your friends if they are looking for one.
DVB-C like DVB-T/T2 are the next generation of TV format. No it will not be switched off anytime soon yet. DVB-C just launched not too long ago. At most starhub will move to DVB-C2 in the near future.
133RMB
Wah, price dropped liao, now 130 RMB (~S$26, buy 5 = 1 Draco)
³§¼Ò¹©Ó¦DVB-T2»ú¶¥ºÐDVB-T2 ÂíÀ´Î÷ÑÇÄÏ ÐÂ¼ÓÆÂ 2014°æ ´øÒº¾§ÆÁ-ÌÔ±¦Íø
Yes, indeed it works. Because the cables are not stiff, I have to use scotch tape to hold down the black and red cables to form the "T" on a wooden ruler.
Below are the results, using Draco stb:
- Chan 27 >90/98 (Signal Intensity/Pic Quality)
- Chan 29 >90/98
- Chan 31 >90/98
- Chan 33 >90/98
- Chan 38 ~90/98
Check with your guys, I just bought my new TV a few months ago. Read from the specs that it supports analog, DVB-C and DVB-T, but not DVB-T2. I connect it directly to the Starhub cable point, no STB. It can receive all the digital FTA channels including HD5. I understand DVB-T2 does not apply to cable, so does that mean that even in the future I need not use DVB-T2 since I am already using DVB-C anyway? Even when they cease analog and DVB-T transmission?
