Possible to buy the kind of wax removing soap, use it before washing your hair with shampoo?
your picture is wearing a hair band ah?
can't see la bro.
your hair shld be the typical asian hair we all have here.
so technically. the usuall stuff you need.
SSS and a good wax.
the most important is the skill of blow drying and styling your hair.
why do you want to buy cheap wax and buy some special shampoo to wash it off?
don't be so cheap leh. lol
just buy a good wax and a good shampoo. usually can last.
give you cheap combo (at most $30)
Vantachi Hair clay (don't worry, works like wax and washes off easily)
Head and shoulders or any off the rack shampoo for men.
luxury combo (almost $60 but got change but this is the real deal, trust me, user and swear by it)
Gold digger
Kanebo Shampoo
i practically sum it up for you. if you still want to use cheap wax or what, by all means.
