Advice for new rig needed
agent_719
Hello, helping my cousin to build a new rig. did some research in the forum and came up with this specs
CPU + MB : i5-4400 + Asrock h81m hds $300
Ram : Crucial 8 GB DDR 3 $90
GPU : Zotac GTX750 ti $205
SSD : Crucial m500 120 Gb $115
HDD : WD Blue 1TB 3.5" SATA 6GB/s
PSU + Case : CM 311 + FSP hexa 500 $105
Drive : Samsung OEM 24x dvddrw $21
Monitor : Dell S2340L 23" $220
KB + Mouse : Logitec MK120 $20
Wireless adapter: use router? or have inbuild adapter?
Budget <$1300
His usage : Dota 2 + MS office + web surfing + light Photoshop
His wants : Preferably a smaller size rig due to limited desk space
Qn: Does the power supply enough for the specs? and is it overkill for dota 2 only, is i3 enough?
thanks in advance for the inputs:)
aaragore
yup psu is fine. 750ti doesnt take up much power
might need wireless adapter, either pci or usb, can be bought quite cheaply too.
as for i3, i suggest i5. this way the pc can "futureproof" abit longer.
my 2 cents
MoneyFace =p
Budget <$1300
This will suffice.
And it is a full blue and black theme system package - PC, keyboard, mouse!
CPU+MB: Intel Pentium G3220 + ASRock H81M-HDS @ $148
RAM: Crucial DDR3-1600 CL11 4GB X2 @ $94
GPU: PowerColor HD 7730 2GB [DDR3] @ $88
SSD: Plextor M6S 128GB @ $119
HDD: Western Digital Blue 1TB @ $72
ODD: Samsung 24X CD/DVD Writer [Retail] @ $21
CASE+PSU: In Win BK644 [Black] + Powerman IP-P300BN7-2 300W SFX [80 Plus] @ $103
At 12.5 litres, still small as many competing mITX chassis even though this is of mATX nature.
DSP: Dell S2340L 23" LED [eIPS] @ $219
PHP: Cooler Master Storm Devastator @ $69
WIFI: TP-Link TL-WN722N Wireless-N 150 Mbps [USB] @ $26
Total: $959
Buy and Build from Tradepac, #05-18.
royfrosty
Dont even need an i3. A Pentium is enough. Not only that. By right you can even run intergrated graphics. Just add in a entry level gpu will give you high settings le.
ASrock B85M DGS + G3220 ~ $143
Crucial 8gb 1600mhz ~ $89
WD blue 1tb ~ $75
Crucial m500 120gb ~ $115 or amazon set $92 (only buy from amazon if you have $125 and above worth of shipping)
Powercolor 7730 1gb ~ $88
Silverstone SG02 ~ $88 (tradepac promo)
Silverstone 500w 80+ ~ $55
Samsung ODD ~ $21
Dell S2340L 23inch eIPS panel ~ $219
Logitech mk120 kb and mouse combo ~ $18
TPLink WDN 3200 n600 dual band USB wireless adapter ~ $45 (only go for this if you have a dual band router and a fibre internet. Else a regular TPLink usb wireless at $18 can do the job)
Total ~ $933 buy at tradepac. Diy
MoneyFace =p
G3220 do photoshop good ?
At least not too slow from Core i3:
And at the same time Jaguar puts Piledriver to total shame with lowest end dual core Sempron beating dual core A4. :s22:
agent_719
Thanks all for the valuable inputs. Appreciate it a lot
Should I tell him to go for power color 2 or 1gb since both same price ??
If don't know how to DIY can go gs shop rite?? May I know the unit number?
royfrosty
Ok. If you can get a 2gb one at the same price sure go ahead.
Yes you can head to GS shop pc care solution. Level 2.
ZawLee
Powercolor 7730 can't play high settings in dota2. Will make gpu high temp and load lag. I have this card so I know.
royfrosty
By right it should work well and flawlessly. I also do know that they have optimizing issues and stuttering issues not only on green camps gpu. They have issues on red camps also.
Heres some benchies on dota 2.
Results: High Details, 1920x1080 - Dota 2 Performance, Benchmarked
On high settings it should be slightly above 6670 and below gtx650. 6670 performance although a older card has a roughly the same horsepower as compared to the 7730 being a slightly faster card.
If there is a need to hit 60fps for dota 2 (which i dont think is needed) atS can go for 7750 or a gtx650 instead.
annoymous
actually dota 2 is more cpu dependent, even with 7850 i couldnt hit 60fps constant on the fx 4100
Honda_
If on resolution 768 should be no problem at all right?
agent_719
discussed with my cousin and he sort of decided with :
CPU : ASrock B85M DGS + G3220 $143 ( He prefer an "i" processor due to friends influence) Can recommend an i3 processor?
RAM : Crucial 8GB 1600MHz $89
HDD : WD Blue 1TB $75
Case + PSU : Silverstone SG02 + SilverStone 500w $55+$88
Drive : Samsung ODD $21
GPU : Any better options compare to Powercolour 7730? He wanted something "futureproof" that can at least last 2 years
Screen : Dell S2340L 23" eIPS panel $219
KB + Mouse : Logitec MK120 $18
Speaker : Logitec Z150 $20+?
Adapter : TPLink WDN n600 Dual Band $45
Total : $773 + GPU
btw Plextor or Crucial RAM , which one is better?? And do i need to install a fan or cooler?
Thanks for the valuable inputs again!
A2yincor
Total : $773 + GPU
Of cause, you should spend a bit more on the gpu. As for the cpu, an i3-4130 will be enough alr. You should spend another $260 for a r9 270. I recommend sapphire, but powercolor works fine too.
royfrosty
Total : $773 + GPU
Then you should at least educate him and telling him, buy something that caters for your need. Not buying something that he dont need it.
No point paying more for something that he do not use.
An i3 is seriously not gonna yield him good "gaming" experience. If he really wants a gpu to be lasting (which i sincerely doubt he needs one since he only plays dota 2) Then he should be serious to look on a GTX750 1gb ~ $169 or a 750ti 2gb ~ $208.
And fyi paying more does not mean futureproofing.
agent_719
thanks a lot! already told him to stick to G3220 since he only dota2 and maybe fifa14, can help my uncle save money too!
RAM : Crucial 8GB DDR3 1600mhz $89
SSD : Crucial M500 120GB $115
Case + PSU : Silverstone SG02 + SilverStone 500w $143
GPU : Powercolour 7730 2GB $88
OS : Win 7 OS OEM $115
total : 1091
:o
MoneyFace =p
total : 1091
:o
Get Plextor M6S 128GB SSD for just $4 more for 2 years longer warranty, extra 8GB and better performance over Crucial M500 120GB.
Why Silverstone SG02? It is not exactly small, FSP Hexa 550W @ $69 should be already in stores now, with 3 years warranty.
