660ti vs 1440p reso?
TechNuB
i own a asus 660ti and i m thinking of getting the 27inch qnix lcd from gmarket
games i play is ROS mainly atm.
do u think my GPU can support 1440p gaming??
many thx!
(btw i m using a 520w seasonic psu.)
MoneyFace =p
many thx!
Can, but anywhere from low to max settings, depending on game resource demand....
TechNuB
ha sry forgot to state..
prefer to mid high settings. no need those AA/AF i cannot tell much
i m worried cuz 660ti lags at time during spell spams in ROS.
royfrosty
Check whether your dvi is dual dvi. Else it wont work.
Next is yes you can run. If you are currently lagging at times of spell spamming. Upgrading it to 1440p is just not gonna be any better.
TechNuB
it does come with dual dvi..
ports shld be no issue..
yea i was thinking of the same issue.
but my concern is actually to what extend will it worsen.
would be best if some 1 else with 660ti or similar is running 1440p gaming...
thx
royfrosty
thx
Bro. dual dvi does not mean 2 dvi ports.
Dual dvi link is in all total Should have 24pins iirc.
Best is check with your card manufacturer.
TechNuB
yea i did wadeva research i could before posting
viiinz
RoS as in d3 Reaper of Souls?
read in reddit/bnet forums that some people with 780s/titans/r9 2xx cards still get frame drops when u have 4 players spamming skills, etc...this is worse in areas like rakkis crossing in act 3...lol
d3 is not a very gpu intensive game, i guess its the software side that has issues :s22:
ZawLee
Even I have issues playing RoS with the amount of FPS dropped during mass spell casting with my friend's crossfire r9 280x msi with 1080p tri monitor.
royfrosty
RoS whatever GPU for now totally terrible if you have 4 people spamming skills.
Not sure why. But dual gpus seems fine with max fps uncap lol. But drop till 60fps @.@.
Anyway TS, 660ti wont be able to get the settings you intended on 1440p ba. Quite demanding.
FinalTidus
1200p still can as i am also using 660ti and dell U2410 monitor.
1440p is very demanding. Suggest you upgrade your monitor and see what kind of settings you can adjust first.
aaragore
even i get frame drops in ROS, rakki's crossing and act V some parts. i dont believe my setup cant support this game fully, should be client problem bah
TechNuB
glad to hear not my gpu issue
what i dont wana end up with is i buy the monitor on impulse liao den realise
my gpu cmi...
den have to change gpu + psu too... burn $$$
ZawLee
Acutally 1440p resolution monitor you can downgrade to 1080p resolution by changing the display at control panel
shadow84
If he is getting the basic qnix, he cant as there is no built-in scalar..
TechNuB
yea thus the qns...
on a side note,
any 1 knows if seasonic M12ii 620W has enough juice for 2x8 pci-e gpu like 770/280x??
TechNuB
yes not for sli/xfire
i did read that other than wattage, the amperage seems to be important too....
Lethal
seasonic m12ii 620w is able to support 2 8pin pci-e gpu but it only has 1 6pin and 1 6+2pin. U have to get a 6pin to 8pin pci-e adapter.
