ViewQwest Fiber Broadband Official Thread
kernel.c
sorry bro, don't want to mislead you, that screen was captured few weeks ago. just now tested again, it is very very slow, about 300KB/s with 10 segments :(
Oh. :p ... so, I'm not alone.
Ok, I've send email to NOC with the MTR and ping output from both VQ and from my office.
Thanks.
franstam
4 hops and sub 190ms latency to the UK? are you for real??
Code:
traceroute 85.236.100.27
traceroute to 85.236.100.27 (85.236.100.27), 30 hops max, 38 byte packets
 1  fnet1-f68-access.vqbn.com.sg (132.147.68.1)  1.913 ms  1.495 ms  1.416 ms
 2  V-PR-EQX-02.vqbn.com (202.73.37.230)  1.478 ms  1.363 ms  1.405 ms
 3  linx1.multiplay.co.uk (195.66.224.224)  188.490 ms  188.456 ms  188.473 ms
 4  ts2.multiplay.co.uk (85.236.100.27)  188.473 ms  188.478 ms  188.422 ms
VQ rocks!!!
franstam
in other words, you give up one LAN port on your existing router and get two LAN ports instead?
:s11:
Yes,
Because it's a dummy switch.
this configuration mention above is when zhone router is in BRIDGED mode, so by right only GE1 port is functioning connecting to your own router WAN port.
at least now you can still use the UNUSED 3 ports remaining on the zhone as a dumb switch in bridged mode.
maylyn
Code:
VQ rocks!!!
Good job well done but more can be done :p
Where is my AMS IX? :D :D :D, VQ users whom deem it a must can list down your name ;) so to show as a collective request.
1). Maylyn
kitsura
Code:
traceroute to 46.151.209.154 (46.151.209.154), 32 hops max, 72 byte packets
 1  202.55.67.41  1.012 ms  23.326 ms  0.882 ms
 2  202.73.37.232 <V-TR-EQX-01.vqbn.com>  0.772 ms  0.837 ms  0.816 ms
 3  203.208.190.241  1.201 ms  1.191 ms  1.078 ms
 4  203.208.153.110  1.323 ms  1.338 ms  2.226 ms
 5  203.208.175.2  143.993 ms  141.858 ms  142.716 ms
 6  * 84.235.94.108 <84-235-94-108.saudi.net.sa>  191.864 ms  198.576 ms
 7  * * *
 8  84.235.110.10 <84-235-110-10.igw.com.sa>  139.301 ms  139.254 ms  139.031 ms
 9  212.102.0.71 <gw.nashirnet.com>  138.908 ms  138.443 ms  138.805 ms
10  46.151.209.154 <46.151.209.154.209.151.46.in-addr.arpa>  153.525 ms  149.741 ms  147.567 ms
This is amazing how VQ managed to get sub 200ms latency to Saudi Arabia!
kitsura
Now there seems to be some problem with KL routing. The latency is higher than US!
Code:
traceroute to 223.25.242.90 (223.25.242.90), 32 hops max, 72 byte packets
 1  202.55.67.41  0.923 ms  0.805 ms  0.978 ms
 2  202.73.37.232 <V-TR-EQX-01.vqbn.com>  0.806 ms  0.793 ms  0.771 ms
 3  202.73.47.6 <switch.equinix.vqbn.com>  4486.889 ms  2702.737 ms  1947.953 ms
 4  202.79.197.191 <p55761.sgw.equinix.com>  7.141 ms  7.014 ms  7.119 ms
 5  10.10.10.2  7.415 ms  7.346 ms  7.527 ms
 6  223.25.240.42  7.799 ms  7.453 ms  8.443 ms
 7  * 223.25.242.90 <edm.sgsupport.asia>  191.824 ms  189.060 ms
andr3wyong
Code:
Code:
$ traceroute edm.sgsupport.asia
traceroute to edm.sgsupport.asia (223.25.242.172), 30 hops max, 38 byte packets
 1  fnet254-f36-access.vqbn.com.sg (202.73.36.254)  4.793 ms  0.856 ms  1.112 ms
 2  V-TR-EQX-01.vqbn.com (202.73.37.232)  2.618 ms  1.982 ms  3.012 ms
 3  switch.equinix.vqbn.com (202.73.47.6)  2.898 ms  2.053 ms  3.434 ms
 4  p55761.sgw.equinix.com (202.79.197.191)  7.082 ms  8.193 ms  7.578 ms
 5  10.10.10.2 (10.10.10.2)  7.803 ms  8.066 ms  9.722 ms
 6  223.25.240.42 (223.25.240.42)  8.112 ms  8.450 ms  7.718 ms
 7  edm.sgsupport.asia (223.25.242.172)  9.227 ms  8.184 ms  8.477 ms
kitsura
Code:
That is not the hostname i'm interested in but kul-c01.ipvanish.com which resolves to 223.25.242.90.
andr3wyong
The latency is probably a server load issue, it only occurs at the last hop with lots of variance (or they ratelimit ICMP).
Code:
                             My traceroute  [v0.75]
edge (0.0.0.0)                                         Wed Jul  9 11:10:17 2014
Keys:  Help   Display mode   Restart statistics   Order of fields   quit
                                       Packets               Pings
 Host                                Loss%   Snt   Last   Avg  Best  Wrst StDev
 1. fnet254-f36-access.vqbn.com.sg    0.0%    95    1.2   4.1   1.1  28.2   4.9
 2. V-TR-EQX-01.vqbn.com              0.0%    95    1.2   3.1   1.1  10.3   2.8
 3. switch.equinix.vqbn.com           0.0%    95    1.9  13.9   1.5 203.4  35.0
 4. p55761.sgw.equinix.com            0.0%    95    7.6   8.1   7.2  14.4   1.1
 5. 10.10.10.2                        0.0%    95    8.0   9.6   7.5  20.0   2.6
 6. 223.25.240.42                     0.0%    95   12.6   9.5   7.8  16.4   2.2
 7. server1.waveedm.com               0.0%    94   22.7  54.6  22.4 242.0  46.6
andr3wyong
e.g. here is a best-case ping:
Code:
$ traceroute kul-c01.ipvanish.com
traceroute to kul-c01.ipvanish.com (223.25.242.90), 30 hops max, 38 byte packets
 1  fnet254-f36-access.vqbn.com.sg (202.73.36.254)  7.914 ms  1.361 ms  1.299 ms
 2  V-TR-EQX-01.vqbn.com (202.73.37.232)  0.937 ms  1.410 ms  0.934 ms
 3  switch.equinix.vqbn.com (202.73.47.6)  1.545 ms  1.466 ms  1.401 ms
 4  p55761.sgw.equinix.com (202.79.197.191)  7.331 ms  7.157 ms  7.287 ms
 5  10.10.10.2 (10.10.10.2)  9.009 ms  7.831 ms  7.862 ms
 6  223.25.240.42 (223.25.240.42)  7.662 ms  7.739 ms  8.045 ms
 7  edm.sgsupport.asia (223.25.242.90)  26.406 ms  25.702 ms  29.208 ms
franstam
i got this:
Code:
traceroute to 223.25.242.90 (223.25.242.90), 30 hops max, 38 byte packets
 1  fnet1-f68-access.vqbn.com.sg (132.147.68.1)  1.592 ms  1.401 ms  1.471 ms
 2  V-TR-EQX-01.vqbn.com (202.73.37.232)  1.444 ms  1.449 ms  1.370 ms
 3  switch.equinix.vqbn.com (202.73.47.6)  2.997 ms  3.723 ms  1.921 ms
 4  p55761.sgw.equinix.com (202.79.197.191)  7.691 ms  7.640 ms  7.664 ms
 5  10.10.10.2 (10.10.10.2)  7.948 ms  8.082 ms  8.141 ms
 6  223.25.240.42 (223.25.240.42)  8.105 ms  8.076 ms  7.994 ms
 7  server1.waveedm.com (223.25.242.90)  34.985 ms  26.218 ms  29.257 ms
