Looking to upgrade my gpu
lamorak
Hi
My current rig is as below, if I only want to change the gpu,
What gpu should I look at? Prefer a more up to date gpu so that i can slowly upgrade the rest of the parts too...
Uses for the PC include watching video, slight photo editing and last playing mostly mmorpg, no fps games...
AMD P2 X3 720
Biostar 790gx 128m
Palit 4850 512mb
2 x 2gb kvr
3tb + 125mb ssd
Samsumg 2233sw
seasonic m12ii 620w
Win 7 Home Premium 64 Bit
zenniz
GTX 750TI, 1.5 times better than your HD4850 and consume alot less power.
jtjt00
You better change your PSU as well to avoid the CM kill your hardwares.
lamorak
sorry forgot to update my psu
i am currently using the seasonic m12ii 620w, still need to change mah?
Hi
AMD P2 X3 720
Biostar 790gx 128m
Palit 4850 512mb
2 x 2gb kvr
3tb + 125mb ssd
Samsumg 2233sw
seasonic m12ii 620w
Depends on your budget.
Godeau
so with a budget of 400, the highest i should aim for is a GTX750TI?
What mmo games are you playing anyway?
You might want to consider changing your processor and mobo as well if your budget can handle(or in the near future). I'm guessing you're on ddr2 rams? have to change those too if you're gonna overhaul. That triple core chip is a relic and will definitely bottleneck by quite a margin..
lamorak
will be playing elder scroll online and archeage...
will be aiming to upgrade mobo and processor soon...
Godeau
Yeah mate u might really want to consider changing them then. Here's some scores on processor scaling for elder scrolls online:
Elder Scrolls Online performance
Granted this is in ultra high settings and on a radeon 270, which is faster than the 750ti(about 10+fps difference on most titles). But this is a pretty decent estimate on how well a processor would affect your gaming experience.
lamorak
thank you for the info
any particular brand for radeon 270 should i look at?
