I am planning to switch my fibre ISP in the coming months.
Can anyone who have been through it share how much down time can one realistically expect ? Any recommendations or advices?
Thanks !
In most cases, time is not a problem as u can keep your existing isp till your new service is ready. Which isp u intended to sign up? Many people could not decide as it is hard to decide.Assumingly you have already got your TP installed, half a battle is won.
The lead time depends on which isp u going for. The best person to advise is their representatives..
If u do not have the TP installed, hahas hallelujah..
Thanks !
You can request to activate Port 2 on TP for your next ISP to ensure it is working before you terminate your existing one.
This can save the trouble and time to wait for your existing ISP to release Port 1 on TP.
Yes. I have decided on my ISP but I think only port 1 can be used so since the current ISP is using Port 1, I wonder how long do I need to wait for opennet to link this Port to the new ISP.
OpenNet can activate port 2 from outside your home. Usually nothing need to be done.
How fast will depend on the new isp as some issue the ticket to OpenNet late or never chase OpenNet.
Regardless of isp, it is strongly recommended that you use a Cat 6 or 5e LAN cable instead of using wifi as wifi has its limitation. To enjoy your maximum speed a Cat 6 or 5e LAN cable is a must. With a good cable, even 995 Mbps local speed is possible.
Yes my home is cat 6 wired to all rooms. I think this point wasn't the subject of the discussion which was about how to minimise downtime while switching fibre ISP.![]()
Does activating Port 2 require the removal of the existing trunking and relaying additional fibre optic cable into the home ?
My existing ISP is on Port 1 and I remember when opennet came to install it, the testing was done only on Port 1. As a matter of fact, I do not recall any fibre optic being "connected" to Port 2.
I doubt so because by right OpenNet should have connected (but not activated) Port 2 during the installation of TP.
It is best to connect the new RSP/ISP on Port 2 to prevent any downtime during the transition of RSPs/ISPs.
Not entirely true. In the initial areas of NGNBN, only port 1 was fused and port 2 was not.
When you are saying Port 1 is fused and Port 2 not, do you mean inside the house or outside the house ? If I remember correctly, there are no optical fibre going to port2 when they install the TP in the house. Does that mean that Openet need to physically add new fibre optic cables by removing the trunking leading from outside my house and to the TP again ?
It could be both inside and outside the house, depending on if the contractor fulfiled the "order" correctly. BY RIGHT they were supposed to fuse BOTH within the house. but sometimes they just fuse only port 1. Thus within house port 2 might not be fused. THis one is the thing you got to confirm when they install your TP.
On the other hand, at your riser 2nd port is always not fused. And no, 1 fibre cable has 2 or more strands. so no need to add new fibre optic cables(the black colored one laid in trunking)
