Hairyworm
Can I confirm on 2 things.
1. When is LACP support gonna come?
2. Where is NAT loopback option? How do we enable that?
Test from iPad. Only AC device at home.
ASUS@SG
Suspended
Testing another new beta build.
There is lot of improvement in this build. Official build coming soon
oric1
Pardon me. Mixed up with MBP. Anyway, this is my ipad speed on 5ghz. Note 3 was lower.
Which iPad? 2, 3, Mini or Air?
My iPad Air able to get more than 150Mbps up & down @ 5GHz (in the same room).
SimonLam
Moderator
Moderator
Got fix:
1. Trend micro speedtest issue with AIProtection ?
2. Improvement over 5Ghz media bridge?
3. Ability to disable the media bridge wifi ssid?
ASUS@SG
Suspended
Testing another new build 288x
We are rushing to resolve most of the bug and improve our RT-AC87U performance.
You guys may see official firmware out soon.
Best regard,
JK
phayze
Is it ok not to factory restore after upgrading firmware?
Best regard,
JK
seller4
Interesting. My Note 3 has higher download and upload speed than my iPad in the same room.
BTW, Note 3 supports WiFi-AC.
SimonLam
Moderator
Moderator
i got 7ms, 160Mbps down 160Mbps up on my iPad Air on 5Ghz Wifi, speedtest to New Media Express server.
phayze
My 5GHz seems to start very slow. Is yours same?
renfred89
yes this is normal as there are 2 different wifi processors running different firmware. 5ghz will start up slower than 2.4ghz.
future updates might or might not improve..
phayze
And also the web server also crash. The port 80 not open after sometime. I cannot go to the main page of the router. Anyone got this issue?
seller4
My Note 3 Speed Test. Using New Media Server. ISP is MyRepublic 1Gbps. Using 5GHz.
renfred89
Sorry bro, dun get u? Are you referring to the link speed between the main n wireless bridge routers?
i mean the link speed between the phone and the router.. I am connected to 5ghz for my note 3, but max is only 100mbps+ on wifi test to new media express server leh.. :(
