i'm interested in this iloome tempered glass leh![]()
Bro, we ask kalasala do the MO la..
but jin expensive~
Items: SGD 33.47
Shipping & handling: SGD 17.40
Total before tax: SGD 50.87
Estimated tax to be collected:* SGD 0.00
Order total: SGD 50.87
Where u get this?? I need it for my neo hybrid also.
I also bought my case off Qoo10 ago store and it arrived on the day iPhone started selling to preorder on 190914. It authentic stuff but mine neo hybrid button not working well.
Looking to use this photo to push them to send me one
This mime tempered glass also quite good..super thin as well..
iPhone 6 Plus Feather+ Glass Screen Protector | MIME
review for the 5s version
https://www.youtube.com/watch?v=1eeZgLN5_dI
IPHONE 6 5.5INCH ANTI SLIP CLEAR SLIM SILICON CASE
IPHONE 6 PLUS ULTRA SLIM <0.2MM SMOOTHIE GLASS SCREEN PROTECTOR
anyways, u should try this. i already got mine.
Momax Clear Flexible TPU Skin Case For iPhone 6 (4.7 inch) - Cases - By Type - Accessories
compared already with spigen. confirm better quality cause the edges got glazing coating, spigen one i think just transparent. easier to attract prints
if you follow this thread closely, you will find that there are many ways to get a SPIGEN CASE. its not some rare brands you see locally.Emailed this fecking richard from spigen sg.
Replied once "will send to you soon" on 16th.
Sent reminder a couple of days ago. No reply.
Fecking hell. What the feck is going on.
First and last time buying from spigen sg site.
assuming if you are thinking that buying from a .SG site will naturally guarantee you a faster shipping then you are so very wrong.
Hey guys.. for the transparent TPU casing, would you all recommend the "open concept" version whereby the volume and sleep/wake button is not covered to give a flushed iPhone?
Or the "closed concept" to prevent dust and dirt from going in?
Is TPU easy to put into and take out of the pocket??
Best TPU case goes to Tunewear softshell and Spigen Capsule for iPhone 6+
Best silicone case goes to Apple silicone case for iPhone 6+
Best clear plastic case goes to X-doria Engage for iPhone 6+
thank you for thisGosh! Deflector Bumper
Review:
- On the bulky side.
- Has gap when bumper wear on. Phone will not touch on surface.
- Button slightly hard to press.
- Protruding camera inside bumper.
Spigen Airskin
Review:
- Super-duper thin.
- Super light weight.
- Protruding camera exposed outside casing.
- Buttons exposed.
- Hard to remove. Might scratch the phone, if not handle well.
Spigen Capsule (Black)
Review:
- Doesn't add any bulk.
- Button easily to press.
- Protruding camera within the case.
- Doesn't showcase the back design of the phone.
Spigen Ultra Hybrid
Review:
- Button might hard to locate and press on.
- Showcase the back design of the phone.
