[Maylyn's Review] ASUS RT-AC66U Dark Knight Rises
eyz
Hi,
Is there any way to speed up the transfer speed to the USB connected to the router? When my Download Master starts running, it's impossible to access to my USB.
Also, I think the latest FW states that we are able to download single file from a multiple files torrent with the Download Master. Does anyone know how to do that?
Nakedtoes
Hi,
the download master cannot make it... i nv use it LOL...
wireless i very happy.
StargazerNoir
i play ard the 5ghz setting and set
beacon interval to 50
RTS treshold to 2307..
performance and range increase.:D
Hi, does this actually help? I am on singtel 150mbps fibre and noticed that on weekends night 10-12 the connection drops. I am using wireless. The connection on my laptop will show 3 bars. I have already set the power tx to 150.
On a sidenote, i tried to update the firmware and it gives me the router cannot connect to asus router message :/
Thanks in advance:)
Dellboy
Hi, just updated from 3.0.0.4.374.5517 to new fw 3.0.0.4.376.2524 and noticed speed drops to 144 mbps using Intel AC7260. Previously, was able to achieve 300mbps on 5GHz band. No change in location of notebook.
I merely restarted the router but did not do a factory reset. Any advice?
eyz
thanks for the response.
wireless wise, i have no complaint.
i forgot to mention that i am referring to accessing the AiDisk (USB connected to the router) from my LAN desktop.
It's just that when the download master is downloading stuffs, I have difficulty accessing to AiDisk via FTP or xxx.asuscomm.com:8081/downloadmaster. I need to pause the task before I can access. Is there a bottleneck?? The task usually running at around 500kb/sec. I'm using M1 200MB Gamer plan.
The download master is a great tools to download my stuffs without turning on my PC. And I'm able to create the task remotely.
Or are there any better alternatives?
Nakedtoes
I dun see a need for the download master.
Once I on pc for abt 30mins most of my show and movie I want already downloaded.
Nakedtoes
Thanks in advance:)
Use wifi analysis to see during peak period are u crashing with yr neighbours channels. Use other channel.
asajji
Same issue here. I also upgraded from 3.0.0.4.374.5517 to 3.0.0.4.376.1123 and speed drops to 144 mbps with asus usb-ac53.
Further upgrade to 3.0.0.4.376.2524 no difference, still at 144 mbps.
Downgrade to 3.0.0.4.374.5517 gets it back to previous 468 mbps.
Suggest you go back until the issue is fixed.
Dellboy
You are right. Went back to 3.0.0.4.374.5517 and it was immediate improvement... it's now connecting at 216Mbps for the notebook and more than 300Mbps for the media bridge (second piece of AC66U), all these located in another enclosed room.
joej
Alternatively, there's a new fork of the security features of 376 but without the new limitations on wireless power.
[Fork] Update for 374.43 available - SmallNetBuilder Forums
StargazerNoir
Well the wifi analysis shows the channel the router is using is fine. But i thought it is set to auto and will automicatically choose the best and less used 5ghz or 2.4ghx band?
rolled back firmware to 3.0.0.4.374.5517, and my ac7260 to an older firmware. Speed much better now. Set beacon interval 50 and that other one to 2307 n... but not much difference.
ASUS@SG
Suspended
ASUS RT-AC66U Firmware version 3.0.0.4.376.2524
Bug fixed:
1. Fixed wireless network unstable issue when there are over 50 clients in MAC filer list.
2. Fixed OpenVPN UI issue. OpenVPN client shows disconnect but it still connect to VPN server.
3. Fixed the NTP sync error issue when manually assign the NTP server.
4. Fixed AiCloud compatibility issue when using IE11.
5. Fixed AiCloud UI issue when generating file share link.
Download: http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC66U/FW_RT_AC66U_30043762524.zip
Dolphin1977
Bug fixed:
my speed decreases from
to
now trying to revert back old firmware
reverting back to old firm ware FW_RT_AC66U_3004374130
same setup with the lastest RT-AC66U_3.0.0.4_376_2524-g0013f52
firmware problem? 3 times i tried.. all 3 times new firmware gave lousy speed
i sticking back to my old firmware :(
jiaqing
After the upgrade when I turned off the 5GHz band. The wireless log displays "2.4GHz disabled" instead of the 5GHz. I think error in the wireless log info.
Another problem I encountered for both the firmware 3.0.0.4.376.1123 & 3.0.0.4.376.2524, when I set the bandwidth to 20MHz for 2.4GHz band, the Rx Rate at the wireless log displayed "-0.0M" as shown below. However when I changed to 40MHz bandwidth the Rx Rate can shows the speed clearly. Any solution to that? I have no issue on 5GHz band only the 2.4GHz band.
SSID: "SINGTEL"
RSSI: 0 dBm SNR: 0 dB noise: -78 dBm Channel: 1
BSSID:xx:Xx:xx:Xx:Xx:Xx Capability: ESS ShortSlot
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
HT Capable:
Chanspec: 2.4GHz channel 1 20MHz (0x1001)
Primary channel: 1
HT Capabilities:
Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ]
Mode : AP Only
Stations List
MAC Associated Authorized RSSI PSM Tx rate Rx rate Connect Time
Xx:xx:xx:xx:Xx:xx Yes Yes -70dBm No 65M -0.0M 00:01:36
SSID: "SINGTEL"
RSSI: 0 dBm SNR: 0 dB noise: -92 dBm Channel: 149/80
BSSID: xx:Xx:xx:Xx:Xx:Xx Capability: ESS
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
Chanspec: 5GHz channel 155 80MHz (0xe09b)
Primary channel: 149
HT Capabilities:
VHT Capabilities:
Supported VHT (tx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Supported VHT (rx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
Stations List
Xx:xx:xx:xx:Xx:xx -76dBm No 52M 39M 00:00:00
ASUS@SG
Suspended
Dear jiaqing & Dolphin1977,
Thank you for your feedback.
I will test the router at our side.
Best regard,
JK
jiaqing
Another feedback. When I started a vpn connection using L2TP or PPTP on my mac OS X 10.9.5, I saw some prompts in the system log;
miniupnpd[471]: unsupported NAT-PMP version : 2
miniupnpd[471]: HTTP Connection from 192.168.1.10 closed unexpectedly
Dellboy
Dear ASUS@SG, any advice if the new fw is fixed?
Otherwise I will just stick with 3.0.0.4.374.5517. Continued use of this fw is giving me better result: notebook with Intel 7260 AC is connecting at 585Mbps located in a separate enclosed room from AC66U.
ASUS@SG
Suspended
Dear Dellboy,
You mean you having problem with wireless link speed?
I am using Intel 7260 AC with latest driver from Intel.
Best regard,
JK
Just Me
Hi, any AC66U owner can tell me which firmware currently has the best wireless range esp for 5ghz and AC and is stable?
