Acoustic Werkes CIEM
xuan87
Can anyone suggest whether a 2 pin socket or reverse 2 pin socket is better?
I think that will depend on whether you want durability or flexibility.
To my somewhat limited knowledge, there are not alot of aftermarket cables that will provide reverse 2 pin socket so if you want to buy new cables, your choices will be limited.
However, I believe the reverse 2 pin sockets will be more durable as there are more surrounding support for the pins, if that makes sense.
So I guess it will be a trade off.
chaud@sg
Picked the reverse 2 pin in the end. Thank for the suggestion!
whatme
Just a A2H-V only la. Hopefully the fit will be good 😀
Swee man! I audi this model before..I think they tune it quite good!
Haha! I think now their skills should be better. My pair of refitted AAW CIEM quality was way way way better!
whatme
Nobody hoot their November Promotion CIEM ah??
i wonder anyone did any name emblem on the CIEM..
Mach3.2
Bro. Collect already? Waiting for your update leh.. hahaha :s13:
Collect liao, quite comfortable, used it for 4 hours +, no soreness in the ear canals. :)
Need to get the angle right, and the IEMs sticks out about 1.5cm.
Plus my right ear canal is a little weird, kind of hard to get it in.
whatme
Aiseh!!!
Quite fast sia...
Can post a picture here? i have bad imagination skills >_<
