Acoustic Werkes CIEM
whatme
One side of your ear canal indeed different sia..
But both got a seal right?
whatme
Seal ok, but the right canal a little hard to insert... :spin:
Next week go back sort it out loh. :s12:
But when you wear your silicone tip, your right canal not loose ah??
Seems like your right canal larger :s13:
Just like my right canal, its slightly larger than left ear. lol!
Mach3.2
My right canal goes in straight it seems...
see the first bend there, after the first bend it's still straight, not like my left canal, my left canal goes in at a angle.
Silicon is kind of loose, but the odd shape of my right ear canal didn't help at all...
whatme
You were able to see your own impression done right? Got any diff bo?
whatme
I didn't look at the impressions... :spin:
Haha! :s22:
No choice liao~
As usual, wear for a week and see still got any issues before going refit.
Learnt it after my refitting issues resolved that time.
Mach3.2
Haha! :s22:
No choice liao~
So far the level of sealing is about the same level as foam...
Don't know should expect a better seal boh, since it's just the tip part that is custom...
whatme
Sorry ah, i still very newbie to these.
But if its about the same level as foam, isnt good already??
Need invite a expert here to consult :s22:
Mach3.2
Oh...
Nevermind, don't sad..
This kind of thing sometimes do kena hiccups
Get your refit done soon and enjoy can liao :s13:
Actually I'm ok with the level of seal, it's just that it's a little hard to get the right side in... :s22:
Mach3.2
Does transparent clear shell oxidize with green algae after some time.
What do you mean oxidizing green algae?
Algae is a biological organism, and cannot be formed through oxidation of acrylic shells. :s22:
I'm sure acrylic won't oxidize too.
xuan87
I think it's because he saw transparent cables that turn green before, so he's wondering if the shell will also turn green.
I think it's more possible for the shell to turn yellowish than to have algae grow on them.
