OnLyOnE
- Jan 7, 2001
Wah, it just pop out by itself without you even touching it??? Thanks for the heads up.Guess I am the first to report problem.
Got my wifi 16gb from one of the Sony store last Sat.
Right out of the box, I inspect the tablet every inch before turning it on. No issue.
Then proceed to setup and play with the tablet.
About an hour of playing, suddenly notice that the bottom strip (not sure what it is called) has popped out. Scary!
Immediately went down for a 1to1 exchange.
New set, I also observe that the strip, both top and bottom is not exactly flush towards the right corner round plate (again, not sure what it is called).
It is slightly "higher" than the corner. But very slight only.
Hopefully all is good with the new set.
Everyone, please check if your set is flush at the right corner, both top and bottom.
Left corner is okay.
Hopefully my is a one-off lemon case.
This picture shows the lemon set, not the new set.
Sent from GAGT Android App
