Sony Xperia Z3 Tablet Compact
OnLyOnE
Guess I am the first to report problem. :(
Got my wifi 16gb from one of the Sony store last Sat.
Right out of the box, I inspect the tablet every inch before turning it on. No issue.
Then proceed to setup and play with the tablet.
About an hour of playing, suddenly notice that the bottom strip (not sure what it is called) has popped out. Scary!
Immediately went down for a 1to1 exchange.
New set, I also observe that the strip, both top and bottom is not exactly flush towards the right corner round plate (again, not sure what it is called).
It is slightly "higher" than the corner. But very slight only.
Hopefully all is good with the new set.
Everyone, please check if your set is flush at the right corner, both top and bottom.
Left corner is okay.
Hopefully my is a one-off lemon case.
This picture shows the lemon set, not the new set.
Wah, it just pop out by itself without you even touching it??? Thanks for the heads up.
Sent from GAGT Android App
OnLyOnE
Lol. I am using it as phone to because of the nano sim and the nano sim adapter haven't arrive
weeguy
For those using it as a phone, are you guys using a wired/bluetooth headset for calls or simply using speaker mode?
sword28
yes, it just suddenly pop out.
all this while I was holding it on my hands.
did not put it in stand, pocket, or bag.
and of course, I did not drop it. :s13:
was handling it with TLC.
hopefully it is just a one-off case where the glue is not applied to standard. :s22:
OnLyOnE
You make me want to buy a bumper. My xperia devices along is naked one, this time round, I might make an exception.
rssd21
Yeah, let it wear some clothes.
Naked is not safe. :D
OnLyOnE
can ask if your bluetooth set is those hang on ear type or normal earphones connected to a device like this?
I got both. Jabra easygo and Sony nfc earphone. Both can use.
OnLyOnE
First charge Saturday evening. Moderate usage (with lte), 17% now...
Albedo
Hmm, my job is mostly deskbound, i am not sure if wearing a earpiece all day looks weird. :s22::s22:
artemov
Just got mine!
The provided earphone can be used to make/listen to calls hor?
Before first use must charge to 100%? Subsequent charging must 100% everytime? I just know never let the charge go too low and charge often.
OnLyOnE
I don't wear my jabra whole day, but when phone... Excuse me... I meant when the tablet rings, I just on the jabra and answer.
