Anker 40w wall charger - can change the usa 2 pin to our UK standard 3 pin plug?
Sherra
Hi..
dont think its really related to iphone except that im gonna be using it to charge my iphones and ipads..
was thinking of getting this, but the 2 pin is abit of a turn off, so wondering if any of u bros here managed to try go sim lim tower or something to find a replacement cable, that allow us to plug in the 3pin plug directly instead of having to go through a adapter?
my bed is pushed against the wall, with only a small allowance left, wont be able to do the adapter + the 2 pin on top, if not it wont be a issue for me.
Melvyn_
Hi..
Pardon me if i'm wrong but the Anker 40w is 3 pin mah. I'm using it right now..:eek:
thenakedshades
Of course no issue. I changed from a flat 2pin to a round 2 pin. Why? Because I was lazy to go sim lim, I use the cable that charge my dslr.
hawkz02
Anker 40w 5 port USB should be 2 flat pin. I do not think there any 3pin one.
@ TS
You can change the cable to any 3pin as long can connect to the USB hub connector and you can get hold of one.I change mine to a 2 pin round type using cable from my old adapter.
Fyi performance will be affect or not this I'm not sure as i never monitor but it get all mine devices charged up quite effectively.
EJB
These anker?
You can get the 3pin ones from Unicell level 2. I bought them for my Ankers.
I bought the shorter (40cm) version as I carry one around and leave another Anker at home.
You can see the OEM cable I got from unicell in the pic. Its a 3pin. I used it in UK also, works fine.
Melvyn_
These anker?
Yeah that one lo. How many 40w are there sia?? :eek:
EJB
Heard there's a new one. Not too sure.
Anyway the ones I ordered from Amazon is 2 flat pins, so I just buy the cable from Unicell and use it with my Ankers. $1.65 only. Buy 5, the lady gave me 5% discount even.
Melvyn_
I think the new one all the ports are Power IQ ready. Whereas the old one only 2 ports have the Power IQ technology.
EJB
unicell at sim lim square?
Yes. I couldn't think of anywhere else more suitable than SLS to get such cables, perhaps SLT, but parking's a chore at SLT. So I prefer SLS. Just avoid HJ Mobile Air :s13:
There are a few gens, the first one is marked with the devices type (iPh, iP, S4 etc), the 2nd one is PowerIQ but doesn't have the IQ sign printed. The 3rd one has the IQ sign printed :)
Melvyn_
Oh means mine is the latest one liao. Power IQ printed. :s13:
EJB
The box is also different in size, 2nd gen has a bigger rectangular box. 3rd gen has a more squarish smaller box.
striker22
I got mine from the MO seller here. It is the 3 pin local plug. More ex then if you buy the US Plug and get a cable change but local warranty so no complain. It is the newest version.
EJB
I average about S$38 per shipment excluding the 3 pin cables via vPost from Amazon for friends. My entire household each has at least 1 Anker, with the exception of me, having 2.
Ordered a lot for friends as they found it useful and good. So far so good, no complains for the price :)
a1v1n_
from which MO and how much? can share? :)
