ViewQwest Fiber Broadband Official Thread - Part 3
andr3wyong
For those with speed issues with Asus routers, the upload speeds have already been upgraded across the board (you can also email NOC to check your upload speed profile)
So there's a high chance your speed is bottlenecked due to some software Config on your PC or your router firmware.
Tips:
- Check if you already have existing background network activity eg yourself or family are torrenting or downloading updates/files
- Disable any 3rd party A/V or firewall software temporarily
- Use Windows 8+ resource monitor to monitor any bandwidth or CPU hogs during Speedtest
- Install latest Asus official or Merlin firmware, then do a hard reset by waiting for router to boot up, then press and hold reset button till router visibly reboots
HTH.
andr3wyong
For those using the smaller Zhone 2301 ONT, there is a known issue with VQ Speedtest and a few other synthetic speed tests - if you do a file download test to Leaseweb SG with a download manager, you should nonetheless see full speeds.
hq83
Tips:
HTH.
monkey saw my PM ?
roo7
Just checking, do we need to reboot the zhone to enjoy the upgrade ?
Usually what's your sequence of power cycling the zhone and router ?
andr3wyong
monkey saw my PM ?
Sorry just saw it. Have been using my phone only to access HWZ lately so haven't replied to all my PMs.
Anyway - have you tested from other PC? What about Softlayer/Leaseweb SNG Speedtest or http://speedtest10.vqbn.com/files/10000mb.bin
andr3wyong
The upgrade is seamless and doesn't require reboot - also doesn't matter which one boots up first
libratiger74
Hmm... looks like router settings issue then. Tests indicate with the TurboQAM you should be able to hit 500+Mbits/s.
Thanks. I checked my Turbo QAM is enabled. Any further advice on what to check in my router settings?
Really scratching my head hard...
hq83
with 8 part download on download manager is abt 80-90Mbyte per sec. still about 700mbps limit.
yup another pc is also the same result.
Tested download from my internal network and able to hit abt 960mbps.
nod32 antivirus also turned off during the test
Ghostrider333
Maybe you could uninstall nod32 first and test? Some antivirus suite tend to still work even though they seem off. :s22:
andr3wyong
Is the Zhone the router or are you using another Asus/etc router?
doki81
very odd...was trying everything and i couldnt surpass 300mbps for last few days...today..i try..then i get this
dont know if this can maintain everyday or not..
doki81
happy too early.2nd test result become like this :(
