andr3wyong
- Mar 5, 2012
For those with speed issues with Asus routers, the upload speeds have already been upgraded across the board (you can also email NOC to check your upload speed profile)
So there's a high chance your speed is bottlenecked due to some software Config on your PC or your router firmware.
Tips:
- Check if you already have existing background network activity eg yourself or family are torrenting or downloading updates/files
- Disable any 3rd party A/V or firewall software temporarily
- Use Windows 8+ resource monitor to monitor any bandwidth or CPU hogs during Speedtest
- Install latest Asus official or Merlin firmware, then do a hard reset by waiting for router to boot up, then press and hold reset button till router visibly reboots
HTH.
Tips:
HTH.
