I suggest you post at SNB Forum (Asuswrt-Merlin), I'm sure you'll be able to get your answer there.
Asuswrt-Merlin - SmallNetBuilder Forums
Thanks oric1, I did nothing. Took a nap, wah la.. it works.
All my problems are solved.
Thanks!
I'm on AC 7260 network card and during my speedtest notice this unusual result. My DL speed only 56Mbps but my DL speed can hit up to 250Mbps. Is my card faulty?
u done the speedtest beside your router or from a distance away?
My viewqwest just upgraded to 1gb plan but I wire connect to ac87u only speedtest 460mb/s,
Without router pc direct wire to ONT can get 920mb/s.
The cable between ONT and ac87u changed 3 time still the same.
firmware also updated.
anyone can help me?
Update to latest firmware then reset to defaults.
Ensure IPv6 is disabled, Trend Micro disabled, QoS disabled, CTF level2 enabled.
can anyone advise?
ASUS RT-AC87U Review: Part 2 - Stress Test - SmallNetBuilder
quote"Even more interesting is that the Quantenna SoC has its own directly-connected Gigabit Ethernet port. So Ethernet traffic to port 1 (if my interpretation of the board photo supplied by RMerlin and shown in Part 1 is correct), has to travel through two RGMII ports to get to the WAN or ports 2-4. "
does that mean port 1 will be slower since it have to passby two RGMII ports to reach the main processor, where port 2 to 3 is directly connected to the main processor?
thanks
Can RT-AC87U configure as Access Point? If this is possible, how should I do it?
To configure Access Point, do I connect via WAN or LAN port?
Dear bolasutra,
Access Point - Plug in LAN cable into LAN Port.
How to configure:
Administration> Operation Mode > Select Access Point(AP) mode> Press Save
Best regard,
JK
Hi all,
does anyone know if I can attach the Asus WL-ANT-157 Antenna to the AC87U? Thanks.![]()
Nice, I didn't know Asus got such antenna. I will give it a try.![]()
Not available in locally, need to order online.
Not cheap, Amazon S$68 for 2 units + shipping to Singapore.
What's the better firmware out currently? I bought mine in September IT show, only just unboxed. The 2.4ghz performance, just 1 wall away, has full bar but performance is subpar. Feels weird, like latency, the webpages have to wait a little before connecting and loading.
