ViewQwest Fiber Broadband Official Thread - Part 3
magix
Just sign up for the promotional plan as per normal, use the same info and if you are emailing in just note that you are doing a recontract.
Any bundled router/TV will be couriered to you.
HTH
andr3wyong thanks for the quick respond. What the email address to sent? Don't think is NOC@viewqwest.com (that the only email address i can remember)
lifeisaplay
will VQ be giving out free trials like MR for two months to try the internet with any charges and no fuss?
runforyourlife
Moderator
Moderator
wanna check smth noob...
during installation, u guys would dump the router,onu into dbbox right?
so if i were to later decide to put router inside living room tv console connected to PS4, convert all my phone lines to lan points, for WIFI to reach my 4room bto apartment, what is the most hassle free solution? To have another router or extender or homeplug in the middle bedroom? Thanks in advance!
stanats
Currently a VQ Subscriber.
Is there a way to avail of this without recontracting?
On $65 plan btw.
or option to top up
$115 for Asus RT-AC66U
$140 for Asus RT-AC68U
$180 for Asus RT-AC87U
andr3wyong
On $65 plan btw.
or option to top up
Unfortunately a re-contract is required to be eligible. Do contact CS by phone (6723 8100) or cs@viewqwest.com to check if you are eligible (may not be :x)
andr3wyong
You can set your routers to Access Point (AP) mode, then link them back to your Zhone via the in-wall cabling.
AKK
Anyone having problems with internet? I can't load a lot of sites. Google and gmail is working fine though.
Sent from GAGT Android App
ra[g]e
Yes something is wrong. VQ guys time to get to work :p
Multiple sites have issues, over multiple PCs.
NicBlais
Engineers are looking into it - looks like an issue with international links at the moment. Will post updates
