The Watch Thread - Part 6
Henabi
Oh yes! The more you use it, the higher the chance of the scales to start curling.
One of my fav straps is this cobra NATO strap. You can see the scales curling!
VA VA VROOM!!!!!!
LiNuxIDIoT
Hi can check for my pam 112 wat strap size n lug size to i choose... wana get some new strap :) any recommendation?
SIL3nc3R
Hi all, wanna check with you guys when u buy panerai from AD does it come with the tool that says panerai on it? I can't post pic so can't really show.
yattokame
NSFW!!!
Ok so I sold my 24mm stingray strap to "oriko" on carousell.....
Look what he put it on.....
THIS IS WATCH PORN!!!
Azrielsc
Nice! I'll observe and see if it curls.
I will go home and take some photos of my wife's 219 strap, which she started wearing last year. It is exactly like yours.
You would be looking at 24mm lug size. Length of the strap depends on your wrist size. Standard original Pam strap length is 115/75mm, if I remember correctly.
So you can choose either a tapered design, ie: 24/22mm, or straight length = 24/24mm
Some info to familiarise yourself with Pam straps: How Big Is A Panerai Strap?
It depends what kind of tool you are talking about. If your Pam is the "newer" version with the quick-strap system, then you should have a black plastic tool. If your Pam is of the classic design with strap screws, then you will just have the flat head screwdriver. Or you can even have a Pam with no tools! :)
  • My 351 & 389 (new quick-strap mechanism): screwdriver and black plastic tool
  • My 219: screwdriver only
  • My 512: No tools!
Cheerio!
pwillie
Realized that this world timer don't do half-hour timing...so not a true worldtimer really... And I'm not going Karachi
iamvintage
End of another work day. My latest hoot. The humble Orient Capital. Sort of the Quartz version of the Bambino. Love the cleaner face and the added day function
SIL3nc3R
Thanks Azrielzc,
I found out from the website mine should come with steel screwdriver and it did. So I'm happy.
yattokame
Besides chuan and hj, what are other reputable 2nd hand watch dealers?
Luxurytime
Luxurykoncept
Goldman luxury
GRluxury
Montres
KOH watches and AK watches (rolex only)
Precisionwatch (rolex only)
Athena
Monster time
JW watches
Collectorstime
Theres one at tanglin halt i cant rem the name
And a few others i cant rem the name
Azrielsc
And continuing with my adventure in Panerai Florence, wife wants to wear my Pam 512 so I had to get her a strap there...
Panerai Shiny Dark Pink Alligator Strap
22/20 98/68mm
Kinda weird that there is only one keeper, though I assume that it is because the straps are so short, having 2 keepers will make the strap look "heavy and crowded".
jase07
Luxurytime
Luxurykoncept
Goldman luxury
GRluxury
Montres
Athena
Monster time
JW watches
Collectorstime
tanglin halt - eric bonfield
r0_ger
omg. imagine a dial swap with black sumo. result is gonna be awesome. seiko brack bay.
Alternatively, just get a black sumo and swap bezel. Should be easier. :s12:
But nothing beats the real thing.
r0_ger
sumo right? where to get the cheapest of this in online or locally?
Yea Sumo! Rather... Blumo!
Locally you can try skywatches. If you are willing to try, can buy from Jap online shop... PM me if u need more info.
