ONEPlus ONE phone
Gex
Hey Guys,
I wanna ask if there is really a difference between a international and China set, apart from the Cyanogen logo at the back. Considering if I should just save the hassle and get a China set from Qoo10, which the seller reflashed it to cyanogen11...Please advice.
There's a slight difference in hardware; The radio in the International version and China version is different. Practically, there's little difference in usage. Lots of people here are using the Chinese version.
Will the Chinese version of the OnePlus One work in North-America? | Gizchina.com
velato2006
I just dropped my phone from 2 feet and the screen cracked.
Anyone know any shops around to get my screen replace?
Thanks in advance.
You can find a screen replacement at aliexpress, which cost around SG$90-100 depending on which store u buy from..:)
shawniiex
tempered sp will prevent cracks meh?
stick 2 pieces of glass together, will crack together also what.
Top layer most likely kenna first.
Like I dropped my phone, the glass chipped. But luckily is the tempered sp.
Like $5-$20 for this protection. More than worth it.
Bobby Goh
Agreed. I dropped my Note 2 3-4 times before, once it even bounced a few times. All times, just the tempered glass sp cracked. $15 for a tempered sp is very cheap for insurance.
shawniiex
Haha yeah. Put faith in it. But a glass sp alone can't protect your phone. Cause the whole thing is prone to dents.
Sigh such is the world we poor people live in.
Rich don't need worry such things, just trade in get new one.
sG_KYo
anyone kanna the OPO not working in Thailand network?
cannot log into any network at all?
my friend T-Loaned my OPO to BKK and now he is stuck there without a working line.
Even tried to buy a thai SIMCard to put in also cannot work.
Best part, SingTel Customer Service is not helping ... apparently they don't know what is a OnePlus One phone.
#EpicFacePalm.
technolust
#EpicFacePalm.
No leh, I was in bangkok just last week. Worked like a charm with starhub simcard.
Mine is the 64g version though I don't think it should make any difference :p
hellhole
tempered glass dun cover the whole screen right? i seen them..and the edge is not covered... still have to get a good case to protect the edges.. the glass helps with direct impact on the middle of screen..
Computeron
if dropped n hit the edge, ur phone corner will hit the ground first, not the glass even if its FULLY cover. glass only protects frontal impact.... tempered glass weakest pt is their corners.
dark_heaven
anyone buying from the phone from oneplus website soon? wanna tompang a clear case. please pm me thanks!
