iPhone 6 Cases [NO SALES/TRADE/SWAP]
sigurros
FYI. Those bros looking for Mujjo leather case. Just saw istudio at orchard central selling. Both 80 and wallet
RandyMarsh
Any bros can share pictures of PSAJ Clear Matte (front and back pictures) with iPhone 6 Space Grey?
Thanks!!!
StanII
hi bros,
any one bought PSAJ but it does not fit tightly when put on?
the one my bro has after putting on, the phone can shift inside abit. :(
*edit*: just realized his PSAJ cutting slightly different, the one bought from the apple store online is the "force" edition
hope to hear from PSAJ owners for their iPhone 6
thanks.
fade_white
hi guys im looking for a tpu gel-type slim case (those <0.5mm kind) that is of a good quality. Currently using those generic china-made low quality case I found in toy outpost, but it's quite loose and the fitting is lousy.
Any better ones that is from a reputable brand to recommend? main things I'm looking for is good grip, fully transparent and good fitting.
Thanks!
ragnarok95
Senior Moderator
Senior Moderator
Thanks!
Rock TPU casing. I got one of it, very good and tight fitting. You can find it online or go bugis buy.
indigo22
i also bought my ROCK from adix...
though a bit pricey compared to market rate, i dont see any other shops selling ROCK casing..
buayloti
This person review the casing really dumb :s13: never remove the protective flim
arcturuz
Thanks!!!
here you go :)
HGNL2
HGNL2_AV1
sigurros
Anyone has the problem of removing the psaj once and when put back on the phone again, the sides of the aj seems deformed and seems to move when pressed at the sides?
