Is it good? How come u are not using?
Which PSAJ would suit my Gold iPhone? Clear Matte or Clear or Smoke?
hi guys im looking for a tpu gel-type slim case (those <0.5mm kind) that is of a good quality. Currently using those generic china-made low quality case I found in toy outpost, but it's quite loose and the fitting is lousy.
Any better ones that is from a reputable brand to recommend? main things I'm looking for is good grip, fully transparent and good fitting.
Thanks!
Any bros can share pictures of PSAJ Clear Matte (front and back pictures) with iPhone 6 Space Grey?
Thanks!!!
Rock TPU casing. I got one of it, very good and tight fitting. You can find it online or go bugis buy.
Bro, you buy from Bugis where?
i also bought my ROCK from adix...
though a bit pricey compared to market rate, i dont see any other shops selling ROCK casing..
Don't feed this kind of lousy youtube troll la.This person review the casing really dumbnever remove the protective flim
Thanks!!!
Caudabe • The Veil - Frost
