[Maylyn's Review ~ Networking] Ubiquiti EdgeRouter Lite
franstam
ok, leave system name server empty.
configure dhcp dns to the router's ip
enable dns forwarding.
any idea how to see what was the dns server ip addresses that were assigned by the ISP?
can't figure out where
CLI command: show dhcp client leases interface ethX
sample output:
Code:
interface  : eth2
ip address : .....     [Active]
subnet mask: 255.255.255.0
domain name: .........     [overridden by domain-name set using CLI]
router     : ........
name server: x.x.x.x y.y.y.y <---HERE
dhcp server: ..........
lease time : 86400
last update: Sun Dec 14 19:05:55 SGT 2014
expiry     : Mon Dec 15 19:05:52 SGT 2014
reason     : RENEW
franstam
Need to tap on the knowledge here.
whats the performance hit on ERL if i turn on PBR to route certain IPs towards a VPN tunnel. what kind of nat throughput can I expect?
Considering if I can get away with getting a budget ERL vs a CCR 1009.
I'm using a RB 2011 now. Love it, but it runs out of steam at 300+mbps.
will be moving from purple to black soon.
afaik if anything disables h/w acceleration, speed will be around 200-220mbps, do correct me if wrong
cyberet
if i use load balancing failover wizard, h/w acceleration is disabled?
still at 160+mbps
ip offload module loaded
ipv4 forwarding enabled
ipsec offload module loaded
i guess load balancing disables h/w acceleration as well.
after i use the wan+2lan2 without bridging, it went beyond the 170mbps limit
ok.. figured out that load balacing is related to pbr which doesn't have h/w acceleration
cyberet
Sigh.. transferred the config from MR to VQ on my ERL, but somehow I can't vpn back to my synology VPN server now :(
diff is thats WAN is dhcp instead of static, and firmware is 1.6 up from 1.5
chaicka
Just need to change the VPN configuration to suit the WAN DHCP-based static ip and it will work just fine. I have 3 site-to-site tunnels running to sites on VQ connections.
cyberet
gave up last night.
try again over the weekend
IKE is getting hits on the stats for wan in, and DNAT, but not the rest
qcatalyst
Hi experienced users,
I am new to ER-POE, and had done setup using WAN-2LAN2 wizard. The WAN connected to existing Smart Switch SG-200 for VLAN from Singtel. Direct connection to switch showing 200Mbps speed. However, when connected through ER-POE, the speed only up to 140Mbps.
Is there anything missing in my setup?
Cyberboy128
U enabled Bridging?
qcatalyst
U enabled Bridging?
I can bridge, below is my config:
interfaces {
bridge br0 {
address 192.168.1.1/24
aging 300
description "Local Bridge"
hello-time 2
max-age 20
priority 0
promiscuous enable
stp false
ethernet eth0 {
address dhcp
description Internet
duplex auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
poe {
output off
speed auto
ethernet eth1 {
bridge-group {
bridge br0
duplex auto
poe {
output off
speed auto
ethernet eth2 {
duplex auto
poe {
output off
speed auto
ethernet eth3 {
duplex auto
poe {
output off
speed auto
ethernet eth4 {
duplex auto
poe {
output off
speed auto
loopback lo {
switch switch0 {
bridge-group {
bridge br0
mtu 1500
switch-port {
interface eth2
interface eth3
interface eth4
Cyberboy128
interfaces {
bridge br0 {
aging 300
hello-time 2
max-age 20
priority 0
promiscuous enable
stp false
ethernet eth0 {
address dhcp
duplex auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
poe {
output off
speed auto
ethernet eth1 {
bridge-group {
bridge br0
duplex auto
poe {
output off
speed auto
ethernet eth2 {
duplex auto
poe {
output off
speed auto
ethernet eth3 {
duplex auto
poe {
output off
speed auto
ethernet eth4 {
duplex auto
poe {
output off
speed auto
loopback lo {
switch switch0 {
bridge-group {
bridge br0
mtu 1500
switch-port {
interface eth2
interface eth3
interface eth4
It might be bridging that causes the issue. U might want to test resetting it and set up without bridging.
qcatalyst
Yes, looks like the bridging causing the slowness. After resetting without bridging showing full speed.
Now, is there anyway to setup eth2,eth3, eth4 as switch without bridging?
Thank you Cyberboy
simic
Bridging = switching at Layer 2.
This guy is a hardware acclerated router. To get full speed, u should setup different subnets n route between the ports.
Once u do L2 bridiging, hw acceleration is turned off, hence the large speed dropoff
qcatalyst
Yes, that's correct.
My final configuration is
ONT <--> Switch <--> ERPOE-5 <--> Switch
With the same switch to do VLAN Untagging, Trunking, and general switching.
chaicka
Thank you Cyberboy
The ports eth2, eth3 and eth4 on ER-POE are switched. Go to the Switch0 interface and set the ports you want to be member of that interface.
qcatalyst
Yes, that's good idea. Now I have 3 usable for ports instead of 1. I set the switch0 as LAN, and distable eth1.
Thank you.
EienShouko
I'm tried to reset my Edgerouter Lite to factory via the hardware button.
I've set static IP to 192.168.1.100, and tried connecting to 192.168.1.1 but it's always destination unreachable.
Anyone know any other methods I can try?
